Release notes of D5 Render
3.1.1 Hotfix
Release date 2026/7/30
Fixes
  1. Flickering or lag in some UI panels
  2. Login timeouts or failures under unstable network conditions
  3. Brushes becoming misaligned or disappearing after a model is updated or replaced
  4. Crashes when opening certain older scenes
  5. Eyedropper Tool in Material Properties not working properly on some devices with AMD graphics cards
  6. Unnatural transitions or shadows popping when switching between scenes with different environment settings
  7. Incorrect sun intensity after switching from an HDRI Sky to a Custom Sky
  8. Incorrect camera field of view in some scenes
  9. Projection mode not being restored correctly, or the first frame shifting when switching between views or clips in Video mode
  10. Camera Movement template effects changing after saving and reopening a project
  11. Section Tool not properly clipping models with HeightField Tracing enabled
  12. HeightField Tracing displaying incorrectly when viewed through transparent materials
  13. Transparency channel output not properly handling water materials or section cuts
Version 3.1
Detailed introduction of new features
Release date 2026/7/8
New Products
  1. D5 Lite for Rhino (beta)
  2. D5 Lite for Revit (beta)
  3. D5 LiveSync Plugin for Blender
New Features
  1. Interactive Presentation
  2. Seasonal Vegetation
  3. Custom Pivot
  4. ACEScg Working Color Space
  5. Stereoscopic Panorama
  6. HeightField Tracing
  7. MeasureLine Asset
  8. Launcher Notification Center
Experience Optimizations
  1. Added control parameters to AI Material Snap
  2. Optimized road network editing in City Generator
  3. Super Resolution Upgraded to DLSS 4.5
  4. Optimized VR visual quality, interaction & stability
  5. XR Tour optimization
  6. Spatial Tour - Dollhouse Mesh Reconstruction Optimization, VR Supports Depth Display
  7. Optimized blending effects between Fog & Volumetric Cloud
  8. Supports ray tracing for 3DGS models
  9. Added Color Linkage & Color Variation to Foliage Material
  10. Optimized Path Tool Display
  11. Supports value retention for Automatic Exposure
  12. Supports uploading in-scene models to D5 Works platform
  13. AMD & Intel graphics cards support D5 SR Widget
  14. Support proxy settings on the Launcher login page
Teams
  1. Supports multiple cloud drive integrations for Team Project Library - Google Drive, OneDrive, Egnyte, Autodesk Construction Cloud (ACC) & Dropbox.
  2. Optimized workflow for Team Project Library
  3. Optimized Worksets management & Multi-editing
  4. Optimized SSO Login
Fixes
  1. Fixed unexpected duplication and generation of Ocean Objects across Worksets in Multi-editing projects
  2. Fixed unexpected content overwriting when the same Worksets are simultaneously edited by multiple users in Multi-editing projects
  3. Fixed the failure of Scatter Cull Areas
  4. Fixed inability to select Vegetation Objects
  5. Fixed inability to mirror grouped models
  6. Fixed the loss of Terrain Presets and modified data
  7. Fixed incorrect display of Vegetation, Grass Materials in specific projects
  8. Fixed incorrect material display in specific scenes.
  9. Fixed desynchronization of Focal Length parameters in Video Mode
  10. Fixed incorrect inheritance of aspect ratio in Video Clips
  11. Fixed incorrect playback effect of Two-point Perspective camera
  12. Fixed unexpected camera offset when frequently switching between Perspective and Parallel views
  13. Fixed inconsistency between video preview and playback/rendered results
  14. Fixed unexpected darkening of Video Clips during playback in specific HDR environments
  15. Fixed unexpected visual jitter when compositing video from Transparent Channel Sequence
  16. Fixed incorrect reflection effects on Ocean surfaces
  17. Fixed overly bright reflections on Water Materials
  18. Fixed disappearance of Material Textures with Triplanar when FPS Booster is active on AMD graphics cards
  19. Fixed unexpected FPS drop when moving emissive objects
  20. Fixed a crash when opening specific projects
3.0.1 Hotfix
Release date 2026/1/29
New
  • Added Specular to Ocean
Fixes
  • Occasional update failure
  • Slower loading performance when opening specific scenes
  • FPS reduction caused by Cesium model loading
  • ADQE movement keys not functioning in orthographic view
  • Abnormal fog reflection on car paint materials
  • Unexpected changes to fog setting values when creating or switching scenes
  • Inconsistency between fog settings and the actual effect, requiring fog to be toggled off and on to take effect.
Version 3.0
Release date 2026/1/7
Render
  1. Ocean
  2. Displacement Material (beta)
  3. Volumetric Clouds and Cloud Presets
  4. Optimized Fog
  5. Enhanced Light Intensity Control for Geo Sky with Adjusted Default Intensity
  6. Added Custom Background Color to Effects
  7. Supports Cull Distance for Content Outside the Viewport
  8. Optimized XR Tour with Enhanced 3D Gaussian Splatting Reconstruction Quality
  9. Optimized Splash Effect with Support for Raindrop Transparency
  10. Supports Material ID Channel Output for Outline Mode
  11. Adjusted Default Exposure Value and Value Range
AI
  1. AI Agent: AI Scene Match and AI Asset Recommendation
  2. AI Image to 3D
  3. Optimized AI PBR Material Snap with Enhanced Matching Accuracy and Variation in Results
  4. Optimized AI Enhancer
Features
  1. Added Free Mode to Navigation
  2. Integrated D5 Works into D5 Launcher
  3. Added Procedural Building to City Generator
  4. Spatial Tour, XR Tour, Showreel, and Cesium Available to Individual Users
  5. Supports direct import of 3D Gaussian Splatting files in .ply / .gs format (alpha)
  6. Resizable Sidebar
  7. HDRI Resolution Control
  8. Supports Texture Maps with CMYK Color Code
  9. Expanded HDRI Rotation Angle Range
  11. Enhanced Scatter Performance and Stability
  12. Optimized Movement and Gizmo Auto-Rotation for Local Coordinate System
  13. Optimized Pop-ups, Prompts, and Interactions
Workflow
  1. Optimized Live Sync and .skp File Import for SketchUp
Fixes
  1. Plant/building shadows clipped in rendered images at specific angle and resolution
  2. Reflections in transparent materials turning black when camera is zoomed out in large scenes
  3. Overly bright render outputs in specific projects with Real-time Path Tracing on, despite consistency between the accumulation effect and the viewport
  4. Incomplete display of mortar joints and other texture details in Top view renders
  5. Unexpected sun and shadow appearance when sun is fully blocked out in cloudy sky
  6. Disappearance of fog around sectioned transparent materials
  7. Disappearance of fog in specific scenes
  8. Unexpected horizontal stripes in Grass materials
  9. Unexpected vegetation disappearance when toggling scatter surface visibility
  10. Crash caused by scatter-related actions
  11. Inability to select character models in specific projects
  12. Grouped Rectangular/Disk light size adjustment issue
  13. Inappropriate UV mapping when applying Image Divide with original UV mode to scatter surfaces on imported .skp models
  14. Inability to update scenes and adjust views when Advanced Camera is enabled
  15. Inability of Scene List to correctly record the Camera Clipping Plane setting
  16. Unexpected reset of parameters when switching back to Perspective view after using Two-point Perspective and adjusting the camera or FOV
  17. Application not responding when clicking the Preference menu or rendering images/videos on specific devices
  18. Frozen application when video render starts while an AI post-processing task is initializing
  19. Disappearance of plants on paths when holding Shift to drag and duplicate the path with “Drop” enabled
  20. Cull Distance missing in Preference which requires a program restart to restore
  21. Inability to return to the initial camera view after activating and then exiting Advanced Camera
  22. Incorrect display of HDRI as a circular shape in specific projects
  23. Incorrect Z-axis dimensions in imported 3ds / .obj files
  24. Specific texts on the interface
2.11.1 Hotfix
Release date 2025/8/29
New and Optimizations
  • Optimized principle view operations
    • Disabled right-click rotation and added support for panning in principle views by holding the mouse wheel
    • Supports automatically returning to the previous perspective view when switching from a principle view
  • Quick return to the previous view
  • Enhanced video rendering efficiency for real-time path tracing
  • Optimized Custom Path with support for batch material editing and enhanced performance
  • Optimized Path tool with better Width control and enhanced workflow
Fixes
  • Crash when opening or switching views in specific projects
  • HDRI turning black in specific scenes
  • Display issue with terrain in specific scenes
  • Occasional inability to show scatters when opening a saved scene
  • Inability to re-generate a scatter after undoing its deletion
  • Default by-model scatter surface creation for vegetation generated by SmartPlanting
  • Inability to select a single plant any more caused by pressing the B key and then the ESC key when a plant model is selected
  • Disappearance of mouse cursor caused by hotkey conflict between D5 Render and other programs
  • Unexpected position change of imported Cesium models when opening a saved scene
  • Display issue with IES files which show as “none” in legacy scenes
  • Loss of IES files when lights are saved in the local library
  • Unexpected display of gizmo in the thumbnail when a model is saved to the local library with FSR on
  • View offset when rendering images in Render Queue
  • Incomplete display of path/scattered vegetation in reflections of rendering outputs
  • Fog on the first frame of rendered videos
  • Display issue with transparent materials in the real-time viewport
  • Materials turning black in the real-time viewport with an AMD graphics card
  • Display issue with the animation controller of .abc models
  • Disappearance of D5 Launcher content on specific devices
  • Incorrect texts on specific parts of the interface
Version 2.11
Release date 2025/7/22
D5 Launcher
  1. Upgraded Welcome Page to D5 Launcher
AI
  1. AI Agent
  • SmartPlanting
  • Plant Schedule
  • D5 Bot
  1. AI PBR Material Snap
  2. Enhanced AI Atmosphere Match
  3. Optimized Post-Ai
Rendering
  1. Upgraded Real-time Path Tracing from Alpha to Official Release
  2. Fully Supports Parallel Projection
  3. Align Views Tool
  4. Orbit Center Icon in Orbit Mode
  5. Exposure Compensation for Auto-exposure
  6. Disc Light
  7. Added Directionality to Rect Light and Strip Light
  8. Added IES Lighting to Point Light and Area Lights with Support for IES Intensity
  9. Added Detailed Stage Light Beam Quantity Limit with a Maximum of 256
  10. Integrated FSR Frame Generation
Features
  1. Advanced Brush
  2. Enhanced Scatter Control
  3. Custom Path
  4. Group Management for Scene List
  5. Camera Target for Video Shots
  6. Added Prompt to Open a Back-up After Crash
  7. Supports More Formats for Direct Import
  8. Optimized .abc file performance
Workflow
  1. Optimized D5 LiveSync for SketchUp
  2. Optimized D5 LiveSync for 3ds Max
  3. Added Group Export to D5 LiveSync for Archicad
  4. Supports Blender 4.3/4.4/4.5 in D5 Sync for Blender
  5. Supports Cinema 4D 2025 in D5 Sync for Cinema 4D
  6. Supports Revit 2026 in D5 Sync for Revit
D5 for Teams
  1. Cesium Integration
  2. XR Tour
  3. 6K and 8K Resolution for Video Output
  4. Optimized Workset
Fixes
  1. Materials with Round Corner turning black on NVIDIA 50 series graphics cards
  2. Unexpected deletion of current view when deleting another scene from Scene List via right-click
  3. Reset of Sun Intensity, Sun Disk Radius, and Caustics of Geo Sky after saving and re-opening the project
  4. Inability to merge projects caused by stuck progress bar
  5. Inability to add to selection using the shortcut Ctrl in Post-Ai
  6. Inability of Object List to save updated scatter after re-generating scatter on an edited surface
  7. Ability to select and move lights, particles, section cubes, and cameras in locked layers
  8. Inability to select materials of certain .abc files
  9. Unexpected watermark display when it’s disabled for new team projects
  10. Inability to open team project after initial save of main Workset with synced models
  11. Possibility to pick materials from read-only sub-worksets and paste to editable ones in team projects
  12. Crash when opening Worksets of team projects in Performance mode
2.10.1 Hotfix
Release date 2025/3/19
Optimization
  • Added scaling and offset settings to Precipitation
Fixes
  • Blurry reflections and vehicle models and light ghosting after enabling real-time path tracing
  • Blurry texture maps after enabling FPS Booster for Complex Geometry
  • Unexpected shut-down after clicking Scatter in certain scene files
  • Crash after importing models with empty Mesh
  • Abnormal illumination range of emissive lights
  • Position jump of the moon in Geo Sky and sudden change in sky brightness during day-night transition
  • Abnormal sun caustics settings and softness overflow after switching scenes
  • Inability to switch aspect ratio after selecting a scene under the image rendering mode
  • Inability to download or save AI post-processed images to network path
  • Inconsistent phasing animation effects between 2.9 and 2.10 in certain scene files
  • Occasional pop-up reminder of insufficient permission when saving files
Version 2.10
Release date 2025/3/5
Rendering
  • Real-time Path Tracing (alpha)
  • Night Sky: Moon, Stars, Milky Way
  • Optimized Snow and Rain Effects
  • City Generator with OpenStreetMap Integration and Shapefile Import Support
  • Added AI Inpainting and Motion Blur to Post-Ai
  • Optimized AI Enhancer and AI Style Transfer
  • Optimized AI Make Seamless
  • Optimized Terrain Tool with Range Settings and Optimized Erosion Layer
  • Optimized D5 Scatter Workflow
  • Optimized Direction Controller for Fly in/out Animation Templates
  • Supports Setting Default Display Unit for Model Position and Size
  • Auto-save of Render Queue before Cancelling Rendering
  • Batch Deletion in Scene List
  • Added French and Japanese Language Options
  • Supports DLSS 4
D5 for Teams
  • OneDrive and SharePoint Integration
  • Supports Setting Brand Watermarks
  • Optimized the Animation Effect of 3D Dollhouse
Assets
  • Hotel & Resort Models
  • New Scatter Templates
Fixes
  • Incorrect rendering of orthographic views
  • Blurry texture maps when FPS Booster for Complex Geometry is enabled
  • Terrain flickers when switching painting textures with FPS Booster for Complex Geometry enabled
  • Blurry custom Multimedia material maps after re-opening the scene
  • Display issues with the Normal map of glass materials generated from the base color map
  • Ineffective scattering color of water materials
  • Incorrect individual UV of water materials from D5 Asset Library
  • Lost Individual UV option of emissive maps when setting custom materials
  • Changed procedurally-generated vines after re-opening the scene file
  • Inability to select all the path nodes
  • Missing target areas when generating scatter
  • Inability to paint coherently on terrain when using the Brush tool
  • Loss of terrains after re-opening the scene when the Windows username has invalid characters
  • Operational issues with D5 caused by GPT Chrome browser
  • Incorrect plant icons in the scene list of previous archives
  • Flickering issue with cars dropping to the ground when rotating the camera or clicking in the scene
  • Inability to recognize virtual tour links with “&” in their filenames
  • Misclassification of plants as “Other Models” when merging projects
  • Occasional inability to play batch-rendered .mp4 videos
  • Occasional inability to open scene files containing procedurally-generated vines
  • Insufficient video memory when re-opening scene files with lots of assets
  • Material selections stuck in scene files stored in NAS
  • Loss of scatter settings when scatter surfaces disappear
Version 2.9.1
Release date 2024/11/15
New and Improvements
  • Compatibility with old mouse cursor mode in Preferrence settings
  • Compatibility with old atmospheric perspective mode in Preferrence settings
  • Disabled FPS Booster for Complex Geometry for rendering outputs
  • Optimized downloaded asset icon
Fixes
  • Inability to use some shortcuts on keyboards with AZERTY and QWERTZ layouts
  • Lag when moving objects using gizmo after long-time operation
  • Camera lag when activating the Fly mode for advanced cameras
  • Inability to reflect material UV changes in real time on livesync models
  • Blurry textures of livesync models in specific scenes
  • Viewport stuck when deleting models in SketchUp after suspending live sync
  • Unwanted resetting of adjusted base color map after using AI Make Seamless
  • Loading of Studio presets stuck at 100%
  • Inability to save presets to Studio when certain assets can’t be found in the corresponding file path
  • Incorrect phasing animation visibility effects
  • Incorrect selection logic when adding models by group for phasing animation
  • Incoherent model size change when scaled with the shortcut key “C” before placing down
Version 2.9
Release date 2024/10/26
New
  1. Terrain
  2. Phasing Animation
  3. Post-Ai
  4. Random Placement
  5. Asset Info Page
  6. FPS Booster for Complex Geometry
  7. Added Voxel Style to ‘Text to 3D’
Optimizations
  1. Optimized Orbit View Control
  2. Optimized Asset Update Reminder
  3. Optimized Scatter Parameter Controllers
  4. Optimized Memory Usage and Loading Speed
  5. Scalable User Interface of Video Mode
  6. Hide/show Controller for Light Range Indicators
  7. Optimized Operation for the Object List
  8. Customizable Shortcuts for Stage Light and Projector
  9. Shortcuts for 3Dconnexion SpaceMouse
  10. Auto Language Adaptation according to the System Preferrence
Workflow
  1. Rhino Group Export and One-time Update
  2. Supports Blender 4.2 Version, Camera Animation, and Geometry Nodes in D5 Sync for Blender
Assets
  1. Elderly&Children Character Models
  2. Indoor and Outdoor Materials
D5 for Teams
  1. Supports transforming videos into 3D Gaussian Splatting files on D5 Showreel
  2. Supports connecting the team asset library with Dropbox to store .d5a, .skp, .fbx, .3dm, and .abc files
Fixes
  1. Loss of Tyndall effect in rendered images
  2. Slow loading of scenes with many texture maps
  3. Inability to set keyframes after disabling the Visibility toggle
  4. Loss of parameters in the Scatter control panel
  5. Inability to reset the adjusted cluster density
  6. Vehicle models stuck at path nodes
  7. Uncleared models from the previous selection when creating a new path
  8. Camera lag when rotating with right mouse button in Path editing mode
  9. Invisibility of light source icons after switching off light sources in the video mode
  10. Dark shadows of grass material following the camera movement in rendered videos
  11. UV Randomizer for water materials from asset library not working unless turned off and then on again
  12. Inability to show local assets with “%” in their names
  13. Inability to recognize external compatible graphics card in benchmark test
  14. Inability to disable the orthographic view buttons when activating the camera of current scene
  15. Inability to expand collapsed layer and object lists on 4K screen
  16. Camera offset in two-point perspectives after sync from SU to D5
  17. Requirement of admin permission when launching D5 after it has been installed for all users
  18. Display issues of the Welcome page when D5 is launched for the first time by a new Windows account after D5 has been installed for all users
  19. Black screen when Rainbow Flare is enabled for HDRI in certain scenes
  20. Seams and misalignment in rendered 16K panoramas of certain scenes
  21. Crash after enabling SR to batch render panoramas for certain scenes
Version 2.8
Release date 2024/7/3
AI
  • AI Enhancer (beta)
  • Added Sculpture and PBR Styles to ‘Text to 3D’
  • Optimized Make Seamless Interaction
Rendering
  • Optimized Semi-transparent Effect for Transparent Materials
  • Added Opacity Map to Displacement Materials
  • Sunlight Caustics
  • Added Sky Color Option to HDRI
  • Rainbow Flare Effect
  • AO Overlay in Preview
  • Lower Peak Memory Usage During Image Rendering
Feature
  • Upgraded D5 Scatter: Save Preset, Cull, Multi-Selection of Independent Models and Optimized Interaction for D5 Scatter
  • Addded Mouse Speed to Navigation Modes
  • Optimized Gizmo Rotation
  • Added Visibility Control over Keyframes of Models and Layers
  • Supports Animated Models’ Controller in Video Mode
  • Supports Community-provided Language Packs
Asset Library
  • Construction Site Models
  • Semi-transparent Materials
  • Scatter Presets
Workflow
  • D5 LiveSync for Rhino
  • D5 LiveSync for Vectorworks
Fixes
  • Scene loading stuck at 99%
  • Occasional freezing when multi-selecting path control points
  • Inability to adjust materials after batch replacing duplicated models
  • Loss of auto-filled sequence numbers for duplicate filenames in the rendering queue
  • Un-displayed HDRI after restoring a history version of the scene file
  • Loss of models when opening files saved in a shared local drive from a network location
  • Lack of detection for Workspace permission and remaining disk space when downloading HDRI from D5 Asset library
  • Remaining icons of deleted lights in the scene after syncing again
  • Two-point perspective and Navigation mode switches after rendering panoramas
  • Camera offsets in two-point perspective rendering
  • Seams in rendered panoramas
  • Unexpected serrated stripes in rendered videos
  • Black spots on glass materials in rendered images caused by depth of field
  • Display issues of certain top-view renderings
  • Display issues of outline effect for certain images rendered at resolutions above 4K
  • Ghosting in certain exported reflection channel maps
  • Unexpected highlighted materials in rendered panoramas
  • Occasional position disorder of channel maps with SR rendering on
  • Unexpected bloom effect when ‘Bloom’ is set to 0
  • Over bright firefly particles
  • Compatibility issues with certain 3D Spacemouse operations
  • Incorrect texts and fonts on UI
2.7.1 Hotfix
2024/5/11
  • Further Accelerated Rendering Speed
  • Enhanced Reflection Algorithms for Moving Cameras
  • Added Emissive Effect to Lowpoly Assets
  • Lowered the Emissive Intensity of Scatter Highlights
  • Added a Hint of Reaching the Limit of the Scatter Surface
  • Optimized the Classification and UI of Scatter presets
  • Optimized the Classification UI of D5 Asset Library
Fixes
  • Blurry shadows cast by emissive materials in preview
  • Overly blurry glass materials when Depth of Field is on
  • Influence of distance on lighting effects in reflections
  • Afterimages of moving lights and emissive materials in videos
  • Influence of material colors on shadows in Clay mode
  • Display error of Geo and Sky effect in Clay mode
  • Black spots caused by strip lights in image renderings
  • Incomplete 2D characters in image renderings
  • Perspective jump when rendering images in portrait orientation again
  • Inconsistent preview and output caused by the cloud shadows in orthographic view
  • Color patches/stripes at the edges of images in sequence renderings
  • Display errors of certain glass and metal materials in image sequence renderings
  • Stripes on water materials behind the glass at certain angles
  • Display errors of water materials in image renderings
  • Black sawtooth on transparent materials in image renderings
  • Display errors of specular materials when multiple reflections occur
  • Black specular materials behind the glass
  • Un-displayed multiple reflections of transparent materials in image and video renderings
  • Black edges of water materials
  • Black vegetation effects in video renderings
  • Shadows not moving with HDRI in video renderings
  • Display errors of fluid particles
  • Display errors of an asset when its map is deleted
  • Mouse jumped to the upper left corner of the screen when starting D5
  • Gizmo not working for grouped objects in a close-up view
  • Position jump of the gizmo when clicking on the pivot point of batch-selected objects
  • Broken material link between interrelated duplicate models when swapping the material template
  • Loss of the set light color after switching between Temperature and Color sections
  • Shortcut key hints not changing with the navigation mode
  • Camera jumping to the eye-level view when pausing playing a video with two-point perspective under the Walk mode
  • Loss of graphics card driver info in the hardware test
  • Loss of models during livesync in some cases
  • Long loading time of a scene heavy in grass materials
  • Compatibility issues of 3DConnexion SpaceMouse
  • UI wording
Version 2.7
Release date 2024/4/25
What’s new in D5 Render 2.7
AI
  • Ultra HD Texture
  • Make Seamless
  • Text to 3D (beta)
  • Upgraded AI Atmosphere Match
  • Optimized D5 SR Output Effect
Rendering
  • Upgraded D5 GI
  • Accelerated Rendering Speed
  • Optimized Grass
  • Optimized Light Source Efficiency
  • Added Affect Transparent ID Feature to Multimedia Materials
  • Colored Transparent Channel Maps for Image Render
  • DLSS frame generation
  • Higher-quality Virtual Reality
Features
  • D5 Scatter
  • 3DConnexion SpaceMouse Support (beta)
  • Light Type Switch and Orientation Control
  • Optimized Viewpoint Navigation
  • Optimized Window Scaling
  • Optimized Render Queue
  • Added Video Templates
  • Added CMD Installation Option
  • Improved Efficiency of Loading and Archiving
  • Added Tutorials On Welcome Page
  • Added Spanish Language Option
  • Supports applying for D5 for Edu inside D5 Render
Workflow
  • Optimized Light Replacement and Material Update Option
  • Optimized Real-time Sync for Max
  • Supports 3ds Max 2025 Version in D5 LiveSync for 3ds Max
  • Supports Sketchup 2024 Version in D5 LiveSync for Sketchup
Assets
  • Added Classification and Search feature for Local Library
  • Optimized Classification and Search for D5 Asset Library
  • New Lowpoly Assets
  • New Grouped Characters
  • New Walking Characters
  • New Volumetric Lighting
Fixes
  • Crashes when ‘Save Compressed Project’ is enabled
  • Position jump of models when pre-placed using shortcut keys ‘R’/‘C’
  • Cameras automatically unlocked when a scene is reopened
  • Camera offsets when batch rendering clips in ‘Perspective’ view
  • Loss of water material’s normal map after compressing the file
  • Stuck viewport when editing a camera path with multiple view carriers
  • Viewport aspect ratio changes when updating a scene in the rendering mode
  • Display issues with water materials near the edges of the window
  • Un-displayed water material behind the glass in rendering
  • Seams in panorama renderings
  • SR image rendering stuck at 99%
  • Crashes when livesyncing 3ds Max models
  • Display error of animated traffic light models
2.6.1 Hotfix
Release date 2024/1/1
New and optimizations
  • Supports undo and redo for camera path editing in Video Editor
  • Supports excluding models from procedural vine generation
  • Support AI-generated texture maps for AO channel
  • Optimized the transition smoothness of camera movements
  • Optimized the algorithm of AI atmosphere match
  • Optimized the count and naming of scenes in Render Queue
  • Optimized the support tool
Fixes
  • Fixed the failure of light keyframes
  • Fixed the failure of UV adjustments to Emissive materials
  • Fixed the issue of blurring HDRI in rendering results
  • Fixed the issue that viewpoint movement would interrupt the Depth of Field editing
  • Fixed the abnormal Intensity parameter of stage lights
  • Fixed the failure of Activate and Pin buttons of PiP window when the D5 window was restored down
  • Fixed the failure of shortcut keys for moving the camera after it focused on a model in the Walk mode
  • Fixed the issue of library search results not starting at the top of the page
  • Fixed the issue where the local library jumped to the ‘All’ category after assets were replaced
  • Fixed the issue of importing video files without recording their file paths
  • Fixed the failure of image output format option after multi-selecting in the scene list
  • Fixed the issue where imported .fbx/.d5a files were not displayed in some cases
how do i activate this technology on a gtx 1080?
Hello, it is implemented inside D5 Render program, with no need to activate it manually. You could see that the video quality is better both in preview and final renders.
The scaling for fluids particles are not implemented yet, I’ve tried and the scaling option is still grey (not applicable) , this is only implemented in the Beta section of the particle assets which include non of the fluid assets which is a shame as i was hoping for the option to scale particles as its available in all other assets. hope it will be added soon.
still now i didn’t get update
Hi, 2.3 will come out tomorrow, thank you for waiting~
where is the section tool? I can’t seem to find it :confused:
Hi mate, you need to open it in the Preference.
