What’s new in D5 Render 3.1
Update Overview
New Products
  1. D5 Lite for Rhino (beta)
  2. D5 Lite for Revit (beta)
  3. D5 LiveSync Plugin for Blender
New Features
  1. Interactive Presentation
  2. Seasonal Vegetation
  3. Custom Pivot
  4. ACEScg Working Color Space
  5. Stereoscopic Panorama
  6. HeightField Tracing
  7. MeasureLine Asset
  8. Launcher Notification Center
Experience Optimizations
  1. Added control parameters to AI Material Snap
  2. Optimized road network editing in City Generator
  3. Super Resolution Upgraded to DLSS 4.5
  4. Optimized VR visual quality, interaction & stability
  5. XR Tour optimization
  6. Spatial Tour - Dollhouse Mesh Reconstruction Optimization, VR Supports Depth Display
  7. Optimized blending effects between Fog & Volumetric Cloud
  8. Supports ray tracing for 3DGS models
  9. Added Color Linkage & Color Variation to Foliage Material
  10. Optimized Path Tool Display
  11. Supports value retention for Automatic Exposure
  12. Supports uploading in-scene models to D5 Works platform
  13. AMD & Intel graphics cards support D5 SR Widget
  14. Support proxy settings on the Launcher login page
Teams
  1. Supports multiple cloud drive integrations for Team Project Library - Google Drive, OneDrive, Egnyte, Autodesk Construction Cloud (ACC) & Dropbox.
  2. Optimized workflow for Team Project Library
  3. Optimized Worksets management & Multi-editing
  4. Optimized SSO Login
Fixes
  1. Fixed unexpected duplication and generation of Ocean Objects across Worksets in Multi-editing projects
  2. Fixed unexpected content overwriting when the same Worksets are simultaneously edited by multiple users in Multi-editing projects
  3. Fixed the failure of Scatter Cull Areas
  4. Fixed inability to select Vegetation Objects
  5. Fixed inability to mirror grouped models
  6. Fixed the loss of Terrain Presets and modified data
  7. Fixed incorrect display of Vegetation, Grass Materials in specific projects
  8. Fixed incorrect material display in specific scenes
  9. Fixed desynchronization of Focal Length parameters in Video Mode
  10. Fixed incorrect inheritance of aspect ratio in Video Clips
  11. Fixed incorrect playback effect of Two-point Perspective camera
  12. Fixed unexpected camera offset when frequently switching between Perspective and Parallel views
  13. Fixed inconsistency between video preview and playback/rendered results
  14. Fixed unexpected darkening of Video Clips during playback in specific HDR environments
  15. Fixed unexpected visual jitter when compositing video from Transparent Channel Sequence
  16. Fixed incorrect reflection effects on Ocean surfaces
  17. Fixed overly bright reflections on Water Materials
  18. Fixed disappearance of Material Textures with Triplanar when FPS Booster is active on AMD graphics cards
  19. Fixed unexpected FPS drop when moving emissive objects
  20. Fixed a crash when opening specific projects
Detailed introduction to some features
New Products
  • D5 Lite for Rhino is a real-time rendering plugin built-in Rhino, designed for Architecture, Landscape, and Interior design. It gives you realistic material and lighting feedback while modeling—no need to leave Rhino or wait to render. The viewport updates instantly as you adjust materials or lighting, making it perfect for rapid iteration. All parameters are saved directly within your .3dm file for easy sharing.
  • D5 Lite and D5 Render work seamlessly together in your workflow. Use D5 Lite for design iteration and real-time previews. For presentation-ready visuals, animations, and advanced detailing, switch to D5 Render. All materials, lighting, proxy models and Geo sky created in D5 Lite support a one-way sync to D5 Render, allowing you to easily finalize your scene.
  • D5 Lite for Rhino includes all features of the D5 LiveSync plugin for Rhino.
  • Supported versions: Rhino 6 / 7 / 8, D5 Render 2.7 and above
  • See the Help Center for full details>
  • D5 Lite for Revit is a real-time rendering plugin built-in Revit, for architecture and interior designers. It gives you real-time feedback while modeling - no need to leave Revit. The visuals sync instantly as you modify materials or move the viewport, helping you speed up design iteration. All parameters are saved directly within your .rvt file, seamlessly integrating into your BIM workflow.
  • Use D5 Lite for real-time iteration in Revit. Once your design is set, switch to D5 Render to create high-end presentation visuals. All your materials, lighting, and proxy models support a one-way sync to D5 Render.
  • D5 Lite for Revit includes D5 LiveSync plugin for Revit.
  • Supported versions: Revit 2019–2027, D5 Render 2.7 and above
  • The new D5 LiveSync Plugin for Blender connects Blender and D5 Render in real time. Edits you make to models, materials, and lighting in Blender sync straight into your D5 scene - no repeated manual syncing or export/import. Modeling and rendering stay connected in one flow.
  • Supported versions: Blender 3.4–5.2, D5 Render 2.5 and above
New Features
  • The Interactive Presentation mode is a new presentation mode in D5 3.1 for building interactive content inside a D5 scene. Users can predefine multiple scene state combinations and dynamically switch between them during playback by clicking on interactive variable sets or 3D triggers, thereby achieving a presentation capability akin to “interactive PPT combined with real-time 3D scene control.”
  • Unlike a linear set of images or a video, Interactive Presentation brings design options and multi-state switching into a single playback flow, so you don’t have to re-edit and re-export each time. It works well for:
    • Design reviews for architecture and interiors — switch materials, furniture layouts, and more.
    • Day-to-night and seasonal or weather changes for landscape and planning design.
    • Immersive showcases for commercial real estate marketing (with VR headset and Pixel Streaming sharing).
    • Fast side-by-side comparison of design versions in internal reviews and client conversations.
  • Enter Interactive Presentation mode
    • Click the “Presentation” button to enter the presentation editing/management interface. The bottom panel shows the show list and slide list; the right-hand panel holds the interaction settings.
  • Create Interactive Variables
    • Interactive variables record state changes across different dimensions of the scene — swapping materials, adjusting light settings, showing or hiding objects, and so on. They are the foundation of every interactive presentation.
      • Entry: in presentation mode, the right sidebar provides an entry to set up variable sets.
      • Variable Set Type: this defines which properties the variable set can control and record.
Property Type Description
Material Object surface material
Property Light source type, intensity, color temperature, etc.Unique and specific parameters for different objects
Atmosphere Enviroment & Effect parameters such as sky, fog, and color grading
Visibility Object show / hide status
Transform Object position, rotation, and scale
Camera FOV(Horizontal), Focal Length, and position
  • Add State: based on the variable set type, adjust the matching parameters in the scene (lighting, materials, camera, and so on), then click “Add State” to save that snapshot.
:warning: Note: When setting a Material variable, you can’t switch the Material Template to Displacement or Grass.
  • Set up 3D Triggers
    3D trigger is an interactive point you place in the scene. During playback, clicking it triggers the state change tied to a variable set.
    • Trigger Types:
      • Actor: An independent carrier displayed at the center of the current viewport by default for immediate visibility; position can be adjusted via gizmo.
      • Object: Designate a specific object in the scene as the trigger; supports selecting 1 object only.
    • Performance
      • Toggle: Click the trigger to cycle through states in order.
      • List: Click the trigger to open the Variable Set panel and freely choose a state.
    • Style
      • Icon: use the default icon style.
      • Text: Supports custom text input — handy for short notes and explanations.
    • Other options:
      • Always Face Camera: keep the trigger facing the current view so it stays visible from any angle.
      • Set Linked Object(Trigger Types): bind the trigger to a model so it moves with that model.
  • Add Slide
    A slide sets the camera shot for playback (viewpoint & scene content) — and selects which variable sets take effect in that shot.
    • Play Option:
      • Set slide playback mode (Manual Play / Auto Play).
      • Set transition animation effects for state switching.
    • Interactive Variable Set Binding:
      • Specify the effective variable set for the current slide, supports selecting multiple sets.
      • Unselected variable sets will not participate in state changes for this slide.
  • Variable Set Button: review every active variable set on the current slide, along with its list of states.
  • Play Presentation
    Click the “Play Presentation” button to enter playback mode.
    • Play Slides:
      • Click the left side to expand the slide list.
      • Click the arrow at the bottom menu bar to switch to the next/previous slide.
    • Trigger Interaction:
      • Click configured 3D triggers.
      • Click the Variable Set button in the bottom menu bar to call up the menu and manually select states.
  • Presentation Settings
    • Playback Settings
      • Auto/Manual Play, Transition Animation
      • Presentation quality and VR quality settings
        • Navigation Tips: Click to view Navigation controls and corresponding shortcuts in playback mode.
    • VR mode:
      • Supports immersive presentation experiences with headset interaction input.
:warning: Note: To use VR mode, first enable the VR Widget under Preferences → Widget.
  • Pixel Streaming:
    • Streams your Interactive Presentation to a browser in real time, so others can view and experience it without installing D5 Render.
    • Once streaming starts, two links are generated automatically:
      • Editor link: full control of the presentation — switch slides, trigger interactive variables, and more.
      • Viewer link: view-only access with no interaction, ideal for sharing with audiences who only need to watch.
:warning: Note: Pixel Streaming currently works on a local network (LAN) only. The streaming device and the receiving device must be on the same network.
  • Seasonal Vegetation lets plant assets change foliage color and branch state with the seasons, for a more lifelike sense of how nature shifts across the year. You don’t need to swap in different seasonal models — just adjust the date, and you can preview spring, summer, autumn, and winter in the same scene.
  • Global Seasonal Settings
    Added “Seasonal Vegetation” setting to the Environment - Weather for global control of all supported plant assets.
  • Per-Plant Seasonal Settings
    • Select a single season-ready plant to set its parameters on its own in the right-hand Inspector.
    • State (days): the day range decides which seasonal look the plant shows.
Day Range Seasonal Effect
1 - 135 Spring
136 - 213 Summer
214 - 270 Autumn
271 - 365 Winter
  • Seasonal Colors: tune the plant’s color for each season independently to match different styles.
  • Following Global Settings: when checked, the plant takes its date and seasonal effect from the global setting under Environment → Weather.
:warning:Note:
  • Plants of the same type placed in a single batch share their Seasonal Vegetation parameters automatically.
  • Multi-select batch editing of these parameters isn’t supported yet.
  • Foliage Variation Color
    • The foliage material adds a Color Variation control that brings random color shifts and natural variation to leaves. It cuts the repeated look of large planted areas and adds realism and depth.
3. Custom Pivot
  • Customize Pivot lets you move a model’s pivot by hand, so rotation, scaling, and other transforms work from a base point that matches your design intent. Move a door’s pivot to its hinge, for example, and it swings open naturally when you rotate it.
  • It helps wherever you need precise control of the transform base — door and window animations, furniture rotated around a specific axis, and whole-group transforms.
  • Feature Access
    With a model selected, use one of the following methods:
    • Click the button on the right sidebar to make the settings
    • Right-click Menu: Select Set “Edit Pivot”
:warning:Note: This feature is unavailable (button grayed out) when multiple objects are selected.
  • Adjustment Methods
Method Operation
Drag Directly drag the pivot sphere in the scene; supports auto-snapping to the object surface.
Precise Input Enter X / Y / Z coordinates and rotation angles in the right panel.
Feature Point Snapping Key points such as the bounding box center and centroid will highlight and trigger auto-snapping when the cursor is nearby.
All operations support Ctrl+Z to undo.
  • Save & Exit
Operation Result
Click “Done” or press Enter Save and Exit
Press Esc Cancel and reset pivot to the original position
Right-click empty space Save and Exit
Switch to another tool Auto-save and Exit
  • Groups & Hierarchy
    • You can set a Customize Pivot on a group itself. Group a double door, move the group’s pivot to the hinge, and the whole group swings open naturally when rotated.
    • Modifying a group’s pivot does not affect the individual pivots of the sub-objects within that group.
    • When you ungroup, the coordinate data at the group level clears, but each sub-object keeps the pivot you set for it.
  • Reset Pivot
    You can return the pivot to the model’s initial position at any time:
    • Right Sidebar → “Reset Pivot”
    • Reset Pivot in the right-click menu bar
  • Notes
    • Keyframe data: Modifying the pivot of a model with keyframes will reset its keyframe data. A confirmation pop-up will appear; selecting "Continue " will clear keyframes and enter edit mode, while selecting "Cancel " will discard any changes.
    • Copy inheritance: Models created via Ctrl+D, Alt+D, Shift will automatically inherit the custom pivot of the source model.
    • Asset replacement: Replacing a model from the Asset Library will not inherit the old pivot; it will use the default pivot of the new asset .
    • Export: When saving as a .d5a file or adding it to the Local Library, Custom Pivot information is saved. The Pivot will remain consistent when the asset is opened in other scenes.
  • D5 now supports the ACEScg Working Color Space, with a wider gamut than the standard Linear-sRGB (Rec.709). In high-dynamic-range and complex lighting, ACEScg holds on to more color detail and reduces clipping and shifts in bright areas, giving you steadier, more realistic color.
  • It suits color-critical work — interior lighting moods, high-contrast scenes such as sunsets, and pipelines that need to match the color space of compositing tools like Nuke and DaVinci Resolve.
  • Working Color Space Settings
    Added Working Color Space setting under Preference - Rendering. This defines the color gamut range for internal engine calculations.
    • Linear-sRGB (Rec.709): the traditional standard working color space.
    • ACEScg: offers a wider gamut that covers more of the visible spectrum — a good fit for high-quality rendering.
:warning:Note: This setting is saved locally within each project file.
  • Material Color Controls
    Material Color control supports switching between Linear-sRGB (Rec.709) and ACEScg.
    • It defaults to the sRGB color space.
    • This change applies to every color picker in the software.
  • D5 now supports the output of Stereoscopic Panorama. Compared to standard panoramas, S tereoscopic P anoramas provide a more pronounced sense of spatial depth and room scale.
  • It suits interior design showcases that give clients a VR experience, model-home walkthroughs for property marketing, and remote reviews where you share a Stereoscopic Panorama online.
  • Feature Access
    • Added these new options at Image → Panorama.
      • Stereo: when checked, D5 renders separate views for the left and right eye to produce a 360° image with real depth.
      • IPD (interpupillary distance): sets the spacing between the two eye views to tune the depth effect.
      • Slices: Balances image quality against render time.
        • More slices produce smoother transitions across the image, but increase render time.
        • Stitching seams tend to show up on objects close to the eye and on wide horizontal lines away from eye level. Raising the slice count helps reduce them.
  • How to View
    The output Stereoscopic Panorama image can be viewed in the following ways:
    • VR headsets (such as Quest, PICO, etc.) devices for an immersive stereoscopic experience.
    • Stereoscopic Panorama players: open in any desktop or mobile player that supports the stereoscopic format.
    • D5 Showreel: create a Panorama Tour project, upload your Stereoscopic Panorama from local storage, and D5 handles the correct online stereoscopic rendering for you.
:warning:Note: Currently, Spatial Tours do not support Stereoscopic Panorama.
  • In the advanced options for the Displacement material height map, a new HeightField Tracing algorithm has been added alongside the existing Subdivision Displacement.
  • The edges of HeightField Tracing materials produce realistic bumps and undulations without increasing the model’s polygon count, significantly improving both the level of detail and the realism of the material.
  • It’s a good fit for materials with surface relief — brick, stone, wood grain, woven textures — and works as a lightweight alternative to Subdivision Displacement in large, performance-sensitive scenes.
  • D5 Asset Library adds the MeasureLine tool, so you can measure real distances between models or across a model’s surface right in the scene. You can check dimensions inside D5 without switching back to your modeling software.
  • Feature Access
    • Click D5 Asset Library→ Model → MeasureLine to activate the tool.
    • Move your cursor into the viewport and the tool auto-snaps, sensing and locking onto the surfaces of models in the scene.
  • Properties
Property Description
Distance Adjust the length of the line segment by hand.
Auto-snap When enabled, it displays the exact distance between snap points. The value updates instantly as you move the mouse or change points. Turn it off for freehand measurement.
Label Position Adjust the position of the measurement label along the line.
Label Scale The size of the measurement label.
Line Style The color and width of the line, and the size of its endpoints.
  • The Launcher adds a Notification Center that brings product updates, task statuses, and account and service messages into one place.
    • See all your important notifications in one view.
    • Filter by type.
    • Manage read and unread states, and jump straight to whatever needs action.
  • AI Material Snap adds several controls so you can shape the result more precisely:
    • Aspect Ratio: pick a preset such as 1:1, 16:9, or 3:4, so the result matches your target size out of the box.
    • Tile Direction: choose Both, Horizontal, Vertical, or None to control how the material tiles seamlessly.
    • Quality: choose Default or High Definition to trade off generation speed against detail.
  • City Generator gains several improvements to its road system and editing flexibility.
    • Road System:
      • Updated the road network data structure; legacy projects upgrade automatically.
      • Added new Road/Road group Style effectors with default styles and support for texture editing.
      • Added intersection as a new road type.
      • You can now edit road control points for more flexible control over a road’s path and shape.
    • Editing, management & fix
      • Batch-selected buildings or roads now support a right-click option to convert them into independent or separated groups.
      • Resolved the watermark issue on city models.
  • Resolved potential issues with ghosting, motion trails, and edge blurring during video rendering.
  • Sharpens overall video output and preserves more detail.
  • This update introduces a comprehensive upgrade to the VR experience, focusing on four key areas: the introduction of smooth roaming, a new VR floating menu, support for quality preset switching, and improvements to streaming stability.
  • Movement modes
    • D5 VR now supports two movement modes, which can be toggled at any time within the VR menu.
    • Both modes support Teleportation (point at a target location and release to jump) and Smooth Roaming (continuous movement via the controller joystick).
Mode Description
Walk Features collision detection; cannot pass through walls. Ideal for standard walkthroughs and browsing.
Fly No collision limits; can pass through models. Ideal for scenarios requiring quick access to any location.
  • Controller instructions
Left Controller Feature
Joystick (Left/Right) Strafe Left/Right
Joystick (Forward/Back) Move Forward/Back
Joystick Press Show / Hide VR Menu
Trigger Switch Raycast Type
Grip (Hold) Roaming Boost (Does not affect rotation speed)
Right Controller Feature
Joystick (Left/Right) Rotate View Left/Right
Joystick (Forward/Back) Ascend / Descend View
Joystick Press Toggle Walk / Fly Mode
Trigger Trigger Interaction / Confirm Teleport
  • VR Floating menu
    • After entering VR mode, press the Left Joystick to call up the floating menu, which includes the following features:
Menu Item Description
Movement Mode Toggle Switch between Walk and Fly modes
Controller Mapping View button instructions to help new users get started quickly
Settings Adjust VR-related parameters
Exit VR Return to Desktop mode
  • VR Quality Settings
Preset Best for
Default Suitable for most devices; provides a balance between performance and visual quality.
HD Higher rendering precision with improved lighting and reflections; suits powerful hardware or static showcases.
:warning: Note : NVIDIA Graphics Cards: display " VR Quality" (with two options: Default and HD). AMD/Intel Graphics Cards do not display quality settings.
  • Stability Optimizations
    • Streaming Link Optimization: Improved streaming stability between the PC and VR devices, reducing latency and disconnection issues.
    • Crash Fix: Resolved an issue where an abnormal VR exit would cause the D5 main program to crash simultaneously.
  • XR Tour is upgraded across three areas: rendering speed, file size, and web experience.
    • Faster rendering: AI-enhanced screenshots replace the traditional rendering process, sharply cutting local render time during XR preparation. The same project now renders in a quarter of the time it took before.
    • More efficient training: The XR Tour training service adopts a new .sog file format, which is just one-tenth the size of a traditional .ply file.
    • Web editor rebuild
      • Powered by D5’s custom WebGPU framework, XR projects open smoothly in the browser.
      • Supports custom camera transitions.
      • Generates iframe embed code for embedding on web pages or third-party platforms.
  • In previous versions, rendering spatial tour panoramas with both indoor and outdoor positions often caused degradation in Dollhouse mesh reconstruction. The new algorithm optimizes reconstruction quality when indoor and outdoor positions coexist.
  • Fixed an issue where custom hotspots and ground hotspots failed to display after entering VR browsing mode on VR headset devices in Spatial Tour.
  • The new Spatial Tour VR supports depth-map rendering, delivering more realistic and immersive VR visuals.
  • In the legacy version (v3.0), fog was rendered directly between the clouds and the camera. As a result, once fog was enabled, volumetric clouds would easily be occluded—an issue that was most apparent in bird’s-eye views.
  • Newly added Cloud & Fog Blending Mode under Preference - Rendering.
    • Enabled: Disables the blending effect between fog and Volumetric Clouds. Fog will occlude volumetric clouds to maintain compatibility with the appearance of legacy scenes.
    • Disabled: Fog and Volumetric Clouds blend naturally, providing superior visual quality.
:warning:Note: This setting is saved locally within the current project.
  • Added Path Tracing support for .ply models. Gaussian Splatting assets now correctly participate in GI (Global Illumination), reflection, and shadow calculations in Ray Tracing mode.
  • Optimized the rendering pipeline for .ply scenes, achieving higher FPS in certain scenarios while reducing peak GPU usage and the probability of stuttering.
  • Added a new Color Linkage option to the Foliage Material Template. When checked, the subsurface color will be linked to the base color.
  • For the Variation Color parameter, see Seasonal Vegetation above.
  • Improved the visual display effect of Path Tool styles. Path segments and control points read more clearly in the scene.
  • When Automatic Exposure is enabled, hovering over the Exposure Compensation slider will display the current total exposure value in real-time.Clicking the “Apply” button will retain the current metering result to maintain scene brightness and automatically switch to Manual Exposure mode.
  • This solves a long-standing pain: once you were happy with Automatic Exposure , switching to Manual meant re-matching the values. Now the handoff from auto to manual is seamless.
  • You can now upload scene models from D5 Render straight to the D5 Works asset platform. Publish models from a .d5a scene in one click — including models made with AI model generation.
  • The D5 SR (Super Resolution) Widget now also supports AMD and Intel graphics cards.
  • The D5 Launcher login page adds a proxy setting. On restricted networks — a corporate or campus network, for example — you can enter proxy server details and sign in directly.
Teams
  • The Team Project Library adds Cloud Drive integration, so you can manage project assets across cloud storage.
    • Connect Google Drive, OneDrive, Egnyte, Autodesk Construction Cloud (ACC), and Dropbox to the Team Project Library.
    • Open projects from a connected drive, and save projects back to it.
  • See the Help Center for setup details>
  • A more efficient way to create and manage projects.
    • Create both standard and Multi-editing projects right in the Team Project Library.
    • Create new folders when saving a project to the Team Project Library from the D5 Launcher or D5 Render.
    • Removed View-only mode Access for Project Library projects.
  • Refined how Worksets and their interactions behave in Multi-editing, for steadier and more flexible collaboration.
    • Ocean and Cesium content no longer take part in Workset assignment; they follow Terrain logic and can be edited only in the Central File.
    • When converting to a Multi-editing project, Sub-worksets generate automatically by Layer, and the assignment interface has been rebuilt.
    • With a Sub-workset open, you can switch between unoccupied worksets directly, without reopening the project (except in Performance mode).
    • Improved Workset lock loss on unstable networks.
  • Improved the SSO Login interface.
Again with awesome update! Thank you so much for the work. You are so consistent with the proper things to update in my opinion. I havent tried everything yet but… guys you are the best!!!
Variation presentation and seasonality - YES! So needed for landscape architects. Updates on speed and size of XR tours is another major thing for small teams. For the daily work - measuring tool is really useful and long dreamt for. Currently - after the update, i am missing the ‘tab’ under model in assets where the measuring supposed to be, i guess it will be fixed. Next level will be the option to see dimension distance when copying object - this is the only thing i miss from Lumion.
All visual and experience optimisations are awesome as well!
Where i can download it to update ???
where it is the update 3.1? I’M still running 3.0.1
A post was split to a new topic: Image Size
Very Nice Updates especially 1. nteractive Presentation
  1. Seasonal Vegetation
  2. Custom Pivot
  3. ACEScg Working Color Space
  4. Stereoscopic Panorama
  5. HeightField Tracing
and Measure Line Option not showing in my system even after update to 3.1
I’m working on very large parking lots in the US, and I often have to place vehicles manually. One feature that would greatly improve my workflow is a button to select all vehicles and randomize their colors automatically.
I hope you’ll consider this feedback for a future update.
Sincerely,
A PRO user of your software.
Again, where is the upgrade for the USA user? I’m still working on 3.01. Can someone respond?
Will there be any updates to the SketchUp version?
Hello D5 Team,
I have upgraded to 3.1 today.
But … where is D5 Lite for Rhino?
Many Thanks!
Andrea
Hi, 3.1 is currently being rolled out gradually and has not been officially released yet. It is not available to all users at this stage. Please stay tuned for the official release. Thanks for your patience!
Hi Andrea,
The Launcher update is also being rolled out gradually. D5 Lite for Rhino is included in the Launcher rollout, so it will become available once your Launcher has been updated to version 1.2.
If you receive the Launcher update notification and update to version 1.2, you will find D5 Lite for Rhino and D5 Lite for Revit under Workflow → Lite.
I think it’s amazing that D5 is always updating and improving its tools. Congratulations
A post was split to a new topic: When I click play presentation it’s just a black screen
Muy buenas actualizaciones, siempre atendiendo las sugerencias de la comunidad, la actualizacion para presentaciones muy bueno
It would be great if the D5 launcher offered the option to update to version 3.1 while keeping the previous version (3.0.1) available, just in case the new version compromises an ongoing project. I feel uneasy about updating and running into issues with current projects, yet I end up missing out on using the tools—something free software already offers.
A post was split to a new topic: File Performance & AI Feature Glitch
I already upgraded D5 from the old version to the newest version — that was right when D5 3.0.1 had just launched on 10/7/2026 — and after I updated it, there were a lot of problems like severe glitching, especially when doing AI post-production. There was an issue where I couldn’t click generate because the button would disappear whenever I moved the mouse toward the ‘Generate’ button. So on 14/7/2026 I downgraded back to version 2.9 and everything went back to normal. Now I see D5 has properly launched the new 3.1 — is it actually okay and safe for me to upgrade now, or is there still a problem when upgrading to 3.1? Because I don’t want a situation where, after I upgrade and save my scene in the new version, I can’t downgrade back anymore since the old version 2.9 doesn’t support it, have u already solve it?
For me too, AI post-production keeps flickering. It’s very annoying and unusable.
I’ve already set everything up in the Nvidia app to see if I have the problem, but it’s not.
