What’s new in D5 Render 3.0
Update Overview
Render
  1. Ocean
  2. Displacement Material (beta)
  3. Volumetric Clouds and Cloud Presets
  4. Optimized Fog
  5. Enhanced Light Intensity Control for Geo Sky with Adjusted Default Intensity
  6. Added Custom Background Color to Effects
  7. Supports Cull Distance for Content Outside the Viewport
  8. Optimized XR Tour with Enhanced 3D Gaussian Splatting Reconstruction Quality
  9. Optimized Splash Effect with Support for Raindrop Transparency
  10. Supports Material ID Channel Output for Outline Mode
  11. Adjusted Default Exposure Value and Value Range
AI
  1. AI Agent: AI Scene Match and AI Asset Recommendation
  2. AI Image to 3D
  3. Optimized AI PBR Material Snap with Enhanced Matching Accuracy and Variation in Results
  4. Optimized AI Enhancer
Features
  1. Added Free Mode to Navigation
  2. Integrated D5 Works into D5 Launcher
  3. Added Procedural Building to City Generator
  4. Spatial Tour, XR Tour, Showreel, and Cesium Available to Individual Users
  5. Supports direct import of 3D Gaussian Splatting files in .ply format (alpha)
  6. Resizable Sidebar
  7. HDRI Resolution Control
  8. Supports Texture Maps with CMYK Color Code
  9. Expanded HDRI Rotation Angle Range
  10. Optimized Path Tool
  11. Enhanced Scatter Performance and Stability
  12. Optimized Movement and Gizmo Auto-Rotation for Local Coordinate System
  13. Optimized Pop-ups, Prompts, and Interactions
Workflow
  1. Optimized Live Sync and .skp File Import for SketchUp
Fixes
  1. Plant/building shadows clipped in rendered images at specific angle and resolution
  2. Reflections in transparent materials turning black when camera is zoomed out in large scenes
  3. Overly bright render outputs in specific projects with Real-time Path Tracing on, despite consistency between the accumulation effect and the viewport
  4. Incomplete display of mortar joints and other texture details in Top view renders
  5. Unexpected sun and shadow appearance when sun is fully blocked out in cloudy sky
  6. Disappearance of fog around sectioned transparent materials
  7. Disappearance of fog in specific scenes
  8. Unexpected horizontal stripes in Grass materials
  9. Unexpected vegetation disappearance when toggling scatter surface visibility
  10. Crash caused by scatter-related actions
  11. Inability to select character models in specific projects
  12. Grouped Rectangular/Disk light size adjustment issue
  13. Inappropriate UV mapping when applying Image Divide with original UV mode to scatter surfaces on imported .skp models
  14. Inability to update scenes and adjust views when Advanced Camera is enabled
  15. Inability of Scene List to correctly record the Camera Clipping Plane setting
  16. Unexpected reset of parameters when switching back to Perspective view after using Two-point Perspective and adjusting the camera or FOV
  17. Application not responding when clicking the Preference menu or rendering images/videos on specific devices
  18. Frozen application when video render starts while an AI post-processing task is initializing
  19. Disappearance of plants on paths when holding Shift to drag and duplicate the path with “Drop” enabled
  20. Cull Distance missing in Preference which requires a program restart to restore
  21. Inability to return to the initial camera view after activating and then exiting Advanced Camera
  22. Incorrect display of HDRI as a circular shape in specific projects
  23. Incorrect Z-axis dimensions in imported 3ds / .obj files
  24. Specific texts on the interface
Note: If an existing scene is opened and saved in D5 3.0, then reopened in version 2.11 or earlier, the fog effect and manual exposure settings may change. If the scene appears white or displays abnormally, please manually adjust the fog height and exposure values to restore normal display.
Detailed introduction to some features
Render
1. Ocean
Introduces Ocean to simulate realistic waves, coastlines, foam, water materials, and physical interactions between water and objects. By adding an Ocean object, a dynamic ocean surface can be created efficiently, with automatic detection of the scene’s terrain range to generate seamless and natural transitions from ocean to coast.
  • Ocean Creation
    • Supports adding ocean from the top toolbar > Terrain.
    • An ocean object is automatically created upon selection and appears in the Resource List.
    • When ocean is selected, its corresponding control panel appears on the right sidebar, enabling adjustments to coastline range, waves, and materials.
  • Surface: Controls offshore large-scale waves and seawater materials.
    • General settings:
      • Height: Controls the sea level height.
      • Wave Scale: Controls the horizontal size of waves. The larger the value, the wider the wave crest.
      • Wave Height: Controls the vertical amplitude of the wave crest, affecting the wave’s volumetric effect.
      • Speed: Controls the flow speed of ocean waves.
    • Material settings:
      • Affects the entire ocean surface material.
      • Absorption: Controls the degree of light absorption in water. Higher values result in deeper water color.
      • Scattering: Controls the light scattering effect, affecting water turbidity and volumetric effect.
      • Depth: Controls the surface transparency.
    • Underwater Volumetric Effect
      • Supports simulation of underwater light scattering and turbidity to enhance realism.
  • Coastline: Controls the effects of nearshore waves, foams, intertidal zone, and transition from land to ocean.
    • Automatic Coastline Generation
      • Supports automatic detection of intersections between terrain/geometry and the ocean surface to generate a coastline with tidal and caustic effects near the shore.
      • Range: For now, the coastline covers a 5120m*5120m area and doesn’t allow adjustments.
    • General settings:
      • Size: Controls the width of the area where wave appears.
      • Nearshore Wave Speed: Controls the movement speed of waves near the coastline.
      • Nearshore Wave Width: Controls the wave coverage range near the coastline.
      • Foam Intensity: Controls the foam brightness.
      • Offshore Foam Size: Controls the distribution and size of foam at the boundary between the ocean surface and the coastline.
    • Coastline Anchor
      • Supports select objects from the viewport or the resource list as the Coastline Anchor, around which the coastline will be automatically generated.
      • Supports individual objects only. Grouped/path-based/scattered/.abc objects are not supported.
      • The coastline area updates dynamically with any addition/deletion/modification of anchor objects, similar to the cull effect of D5 Scatter.
      • Allows up to 50 objects to be set as Coastline Anchors.
    • Auto-refresh of Coastline Range: The following actions lead to auto-refresh of the coastline rage:
      • Adjust ocean surface height
      • Sculpt and modify terrain
      • Modify terrain range
      • Add Coastline Anchor objects
    • Manual Refresh of Coastline Range: The following actions require manual refresh of the coastline rage:
      • Delete/edit Coastline Anchor objects
    • Coastline Material settings
      • Based on the height difference between the ocean surface and the ground: as the distance decreases, the color shifts toward the coastline material; as the distance increases, it shifts toward the ocean surface material.
      • Absorption: Controls the dark-to-light transition of nearshore water material.
      • Scattering: Controls the water turbidity near the shore to create a natural shallow water area.
Integrates True Displacement into the Displacement material template, achieving realistic relief and bumps by altering physical model geometry rather than relying solely on a parallex effect.
  • Displacement Types
    • Parallax Displacement (Original): Simulates the bumpy visual effect through material shading without modifying the physical model geometry, resulting in lower resource requirement and faster rendering speed.
    • True Displacement (New): Modifies the physical model geometry based on the Height map to create realistic bumps and undulations, making it suitable for high-precision materials and close-up shots.
  • How to Use
    • Pick up a material and select the Displacement material template.
    • Insert a Height map and enable True Displacement within More Settings.
    • Note: The “More Settings” menu is not available when the Height map is missing.
  • True Displacement Settings
    • Subdivision Level: Controls the number of mesh subdivisions. Note: Higher Subdivision Levels create finer displacement effects, but it will increase the number of geometries, thus increasing memory usage and rendering time. Please set an appropriate value based on the hardware performance.
    • Vertical Offset: The current displacement algorithm elevates geometry along its normal while preserving the model’s original position. When the model is positioned on the ground, this can result in a visual effect where the model appears raised. To address this issue, Vertical Offset can be applied to adjust the model’s overall position. By fine-tuning the offset value, the model remains aligned with the ground, preventing floating or clipping artifacts.
    • Maintain Continuity: Ensures the model’s solid structure remains closed and complete, preventing fractures or cavities.
    • Remesh: Improves the model topology quality to fix issues such as inconsistent triangle sizes or messy topology.
      • Off: Subdivision is based on the original topology.
      • On: Subdivision is based on the reconstructed meshes.
  • Note:
    • The True Displacement toggle is disabled for live-synced models, which currently don’t support true displacement.
    • To apply true displacement on live-synced models, please first convert them into non-live-sync status by selecting the models from the Resource List and right-clicking to activate the “Non-Live sync” mode. However, this setting will become ineffective if the model is replaced later through LiveSync plugins, and the True Displacement option will become unavailable again.
Introduces Volumetric Clouds with cloud presets and advanced settings, enabling authentic volumetric effects and flexible sky appearance creation.
  • Added Volumetric Clouds to Environment > Weather.
  • Contains multiple built-in cloud presets including Cumulus, Stratocumulus, Stratus, Altocumulus, Cumulonimbus, Cirrus Clouds, and Clear Blue Sky.
  • Advanced Cloud Settings: Contains advanced options to customize the cloud appearance for different weather and lighting conditions.
  • Compatibility
    • When opening scenes created with earlier versions of D5 Render, the cloud effects remain consistent with the original scene.
    • Includes a “Legacy” preset for compatibility with historical projects.
4. Optimized Fog
  • Separation of Color and Density
    • Separated the Color and Density settings, enabling more intuitive operations.
    • Color controller: Determines the fog color and brightness.
    • Density slider: Density becomes an independent setting with a smooth linear response to slider adjustments and an expanded value range.
  • Added Intensity Follows Skylight
    • Controls whether the fog brightness is affected by skylight.
      • When enabled, the fog brightness changes with the skylight intensity, creating a natural and consistent appearance.
      • When disabled, the fog brightness is independent from the skylight intensity.
    • Default settings:
      • When a new project is created, “Intensity Follows Skylight” is checked by default.
      • In previous projects, “Intensity Follows Skylight” is disabled by default to ensure compatibility with the original fog effect.
  • Added Base Height
    • Base Height offers a larger value range and more precise control than the previous Height option.
      • Range: -1000 m ~ 0 m ~ 1000 m with a default value of 0 m.
    • Optimizied logic:
      • The position of the fog layer’s base (lowest point) in the previous version was automatically calculated based on the model’s bounding box, potentially causing the fog layer height to shift unexpectedly as the camera or model changes.
      • The new version enables manual setting of the fog’s base height, ensuring stable fog layer height across scenes.
  • Optimized Parameter Names and Interactions
    • Renamed the Falloff parameter as “Height”, and improves the slider interaction with a smooth linear response.
  • Note: When opening and saving a project made with earlier versions in D5 3.0, and then opening it again in D5 2.11, the fog effect may change, which requires manual adjustments to corresponding settings.
  • Added Sunlight Intensity, Sky Background, and Ambient Light Compensation to Geo Sky > Intensity. Supports adjusting the Sunlight intensity and Sky Background intensity separately, which are linked with each other by default.
  • Supports flexible control over the influence of sky light on scene illumination and overall light contrast, without affecting the sky color, via the Ambient Light Compensation option.
  • Three intensity options:
    • Sunlight Intensity: Controls the direct light intensity.
    • Sky Background: Controls the brightness and saturation of the sky background.
    • Ambient Light Compensation: Controls the influence of sky light on the illumination of the scene, without affecting the blue tint of the sky. It can be used to fine-tune the light contrast.
  • Legacy project compatibility: When opening previous scenes and enabling advanced intensity parameters, the system will automatically calculate these parameters to ensure outputs remain consistent with the previous versions, avoiding brightness differences.
  • Adjusted Geo Sky Default Intensity: Optimized the default brightness of the Geo Sky to achieve natural initial illumination in new projects.
  • Added Custom Background Color to Effect>Style for a flexible control over the background color in the 3D viewport.
  • This feature meets the request of custom background color in specific projects, such as rendering composition materials or parallel projection views.
  • Notes:
    • Parameter priority: This setting will be overridden by the background color set in the Outline mode. Disable the Outline mode to restore the custom background color.
    • This parameter only affects the viewport background and does not change models, environment lighting, or reflections.
  • Added Outside the Viewport option to Preference > Rendering > Cull Distance, which controls the visibility range for content outside the viewport. This setting affects both the viewport and image/video outputs.
  • Best Practice: Enable this option to fix the issue where a plant behind the camera disappears from the transparent material reflections.
  • Enhanced the 3D Gaussian Splatting algorithms, bringing in significant improvements in reconstruction and convergence quality.
  • The Raindrop Transparency option in Environment> Weather> Precipitation now affects the water splashes, creating more realistic rain effect.
  • Supports outputting material ID channel map for image/video renders when the Outline mode is enabled.
  • Optimized Exposure Default Value: Fixed the issue where the default exposure value is over high under manual adjustment mode and adjusted the exposure value range.
  • Compatibility with Legacy Projects: Supports automatic calculation of the exposure value when opening legacy projects in D5 3.0 to ensure consistent effect.
  • Note: When opening projects saved with D5 3.0 in earlier versions, the exposure value may require manual adjustments.
AI
12. AI Agent: AI Scene Match and AI Asset Recommendation
  • AI Scene Match
    • Supports intelligent lighting and environment setup for models based on intent descriptions assisted by AI Agent.
    • How to Use:
      • Describe requirements to AI Agent, such as optimizing the atmosphere, adjusting the scene to an autumn dusk look, enhancing the visual quality, adjusting color tones, or changing the scene to a specific artistic style.
      • AI Agent generates a reference image based on the current scene and camera settings and automatically mapping the generated atmosphere from the reference image to the scene.
      • Supports auto-recommendation of assets from D5 Asset Library based on the materials/models in the reference image, improving scene creation efficiency.
      • Integrates semantic iteration into AI Agent, enablign refinements to the reference image by prompts.
  • AI Asset Recommendation: Supports image/text recognition.
    • Supports uploading reference images to quickly obtain model recommendations. Image size limit: 10 MB.
    • Enter text prompts to quickly find assets and apply them to the scene.
    • Best Practice: Enter “Please recommend tree varieties suitable for aerial-view projects”, and AI Agent will recommend models matching requirements for quick application into the project.
  • Quick light source adjustments: Supports intelligent parameter adjustments for artificial light sources via semantic commands.
  • Issue Report in D5 Bot
    • Added Issue Report: Supports automatic AI-generated summaries of issues and descriptions, along with manual screenshot uploads, to create reports ready for submission to the D5 Support team.
    • After submission, the system automatically creates a support ticket and sends response to the associated D5 account email, ensuring timely follow-up.
13. AI Image to 3D
Introduces AI Image to 3D which enables intelligent model generation from reference images.
  • Main-view image:
    • Supports uploading a main-view image for model generation.
    • Supported formats:.jpg,.jpeg, and.png
    • File size: up to 10 MB
    • Upload Guides
      • The quality and clarity of the reference image has a significant impact on the generated 3D model.
      • High-resolution images are recommended (preferably above 1040 x 1040 pixels).
      • Images with simple backgrounds, sufficient lighting, and complete and clear display of the object are recommended.
  • Multi-angle views:
    • Supports uploading up to three images from different angles with Multi-angle views enabled. AI Agent will analyze all the image information and reconstruct the object from multiple angles to generate a complete and detailed 3D model.
    • Supported formats:.jpg,.jpeg,.png
    • Upload Guides
      • All pictures should be different angles of the same object for best results.
      • Please avoid uploading pictures including multiple objects or mixed views to prevent AI confusion.
      • Picture order does not affect generation results.
  • Model name: after entering a name for the 3D model to be generated, click the Generate button to start a generation task.
  • Use a Fixed Seed: Using the same prompt with a fixed seed produces consistent results, making it easy to reproduce specific models.
14. Optimized AI PBR Material Snap with Enhanced Matching Accuracy and Variation in Results
  • Enhanced the matching accuracy between reference images and AI-generated materials, with slightly improved variation in each generation result.
15. Optimized AI Enhancer
  • Improved image definition and details for results generated by AI Enhancer.
  • Optimized enhancement logic for interior projects.
Features
16. Added Free Mode to Navigation
  • New Navigation Mode: Free
    • Integrated Orbit and Fly into Free mode for flexible and friendly navigation control.
  • Navigation Presets:
    • Added navigation presets matching SketchUp, Rhino, 3ds Max, and Revit, along with default D5 presets, under Navigation > Settings. Changes take effect immediately upon switching presets.
    • Compatibility with old navigation modes:
      • D5 Preset 1 (Default) for Fly mode
      • D5 Preset 2 for Orbit mode
  • Customizable Shortcuts
    • Supports setting custom shortcuts for navigation presets.
  • Navigation Guide:
    • Added a navigation guide, helping users quickly adapt to new navigation modes.
    • Supports revisiting the guide from Menu > Help after it has been completed once.
  • Please visit Help Center for detailed guide.
17. Integrated D5 Works into D5 Launcher
  • D5 Works is a dedicated 3D asset platform for architects, landscape architects, and interior designers, designed to help creators efficiently access and manage high-quality resources.
  • Integrates D5 Works into D5 Launcher, enabling seamless asset exploration, downloads, and management within D5 Launcher.
    • Works Online Library:
      • Supports direct browsing and downloading of 3D models and materials within D5 Works. Download progress is displayed on the asset detail card, consistent with interactions in D5 Asset Library.
      • Storage location: The Default location is D5 WorkSpace\content\OtherAssets. Supports setting the storage location for individual assets from their respective detail pages.
      • Right-click the asset thumbnail to bring up the menu options:
        • Download (when it’s not downloaded)
        • Show in Folder (when it’s downloaded)
        • Favorite
        • View Details
        • Report a Problem
      • Supports adding downloaded D5 Works assets directly to SketchUp or D5 Render.
        • Click a downloaded asset and move the mouse to the viewport of SketchUp or D5 Render, which will turn into an asset thumbnail.
        • Left-click in the viewport to confirm the asset position. A progress bar appears to indicate the import status, and the asset is placed at the target position upon successful import.
    • My List: Supports quick access to the favorited and purchased assets, including free assets.
18. Added Procedural Building to City Generator
  • Styles
    • Supports generating stylized appearance for buildings after enabling the Styles option.
    • Includes three styles: General (default), European, Glass Box
19. Spatial Tour, XR Tour, Showreel, and Cesium Available to Individual Users
  • Formerly Teams-exclusive features including Spatial Tour, XR Tour, and the tour editing platform Showreel, along with a brand new MySpace, are now available to individual users, enabling smoother creation and sharing of immersive virtual spaces. Cesium, the 3D geospatial data platform, is also supported for individual users now.
  • Tours create an interactive virtual space for real or conceptual places. D5 offers a comprehensive suite of solutions—from foundational to advanced—to transform designs into dynamic, interactive, and shareable virtual spaces. Supports exploring the space through a browser.
    • Virtual Tour: Quickly and easily transform 360° panoramas into interactive online tour experiences.
    • Spatial Tour: Set camera views and positions in D5 Render to export a tour with accurate spatial data and advanced features like floor plan.
    • XR Tour: Utilizes 3D Gaussian Splatting to transform the rendered scenes into high-quality 3D space that can be freely explored in any browser.
  • Upgraded MySpace & Showreel
    • Integrates Showreel into the left sidebar of MySpace for streamlined tour management, editing, and sharing.
    • Supports managing and viewing the account info including profile, subscriptions, and feature usage within MySpace.
  • Cesium: Supports importing real-world geospatial data into D5 projects to create accurate and realistic site contexts.
20. Supports direct import of 3D Gaussian Splatting files in .ply format (alpha)
  • Supports importing 3D Gaussian Splatting files in .ply format (alpha) to directly load 3D GS models.
21. Resizable Sidebar
  • Supports resizing left and right sidebars for smoother operation experience.
22. HDRI Resolution Control
  • Added HDRI Resolution to Preference > Rendering with 2K, 4K, 8K, and Actual Resolution options. The resolution setting affects both real-time viewport and image/video output.
  • The Default setting, Adaptive (recommended), inherits the logic of previous versions, which compresses HDRI to 2K resolution for viewport to boost FPS and reduce VRAM consumption, while supporting a panoramic background up to 8K resolution for image/video renders.
  • Note: Higher resolutions consume more graphics memory. Please set the resolution appropriately based on hardware capabilities to avoid lag or crash.
23. Supports Texture Maps with CMYK Color Code
  • Supports direct import of texture maps with CMYK color codes. In previous versions, CMYK textures had to been converted to RGB before importing to D5 Render to avoid display issues.
24. Expanded HDRI Rotation Angle Range
  • Expanded the HDRI rotation angle range to -7200° to +7200°.
  • 360° represents a full rotation. Negative and positive values indicate opposite directions.
25. Optimized Path Tool
Optimized the operation and control logic of Path tool, enhancing the fluidity and flexibility of path creation and editing.
  • Optimized Path Drawing Operations
    • Handle Length
      • Added Handle Length to Curve path mode, allowing precise control of handle length at both ends of path nodes for finer curve adjustments.
    • Optimized Interactions
      • Selecting the path endpoints and clicking on the path activates path drawing insteading of adding a new point to the existing path.
      • In path editing mode, right-clicking with mouse in Path Point mode no longer exits the editing state, preventing accidental interruptions.
  • Separate Control for Different Types of Assets on Paths
  • Added Random Seed
    • Random Seed controls the randomization effect of path objects.
    • When any of the Random Spacing, Random Rotation, or Random Scaling parameters are set above zero, Random Seed can be adjusted to generate varied object distribution patterns, resulting in more natural and diverse path effects.
26. Enhanced Scatter Performance and Stability
  • Optimized Performance
    • Improved the efficiency and stability of Scatter operations and reduce memory usage.
    • Enhanced operation smoothness in complex and large-scale projects.
  • Optimized Advanced Brush Prompts
    • Added a prompt indicating that Advanced Brush cannot be applied to models with incorrect surface orientation.
27. Optimized Movement and Gizmo Auto-Rotation for Local Coordinate System
  • In previous versions, gizmo rotated with the model under Local Coordinate System, which could cause an axis to face away from the camera, leading to operation inconvenience.
  • In D5 3.0, the system automatically calculates the angle between the camera and axes after each rotation. When an axis forms an obtuse angle relative to the camera, the system reverse the axis direction, ensuring the axises always facing the camera and improving ease of use.
  • This optimization only affects the orientation of Gizmo and does not alter the actual rotation logic or outcome.
28. Optimized Pop-ups, Prompts, and Interactions
  • Optimized the style and content for pop-ups related to model synchronization and replacement.
  • Optimized update-related pop-ups in D5 Launcher for clearer information display.
  • Added hover tips to toggles in menus for easier state identification.
  • Other prompt text optimizations:
    • Added a pop-up warning that deletion of video clips cannot be undone.
    • Added a pop-up including operation guides after the error message of “Insufficient permissions. Please retry with administrator privileges.” appears when downloading D5 Asset Library assets / demo scenes on Welcome page / D5 Sync plugins.
    • Optimized the SSO login error message with a clear explanation of whether SSO is not enabled or not configured within the organization.
Workflow
29. Optimized Live Sync and .skp File Import for SketchUp
  • Optimized Material Priority Logic to improve the material display accuracy of complex components or nested models, reducing incorrect overrides.
    • Old Logic: Front materials → Back materials → Parent component materials
    • New Logic: Front Materials → Parent Component Materials → Back Materials
    • The new logic applies to both Live Sync and direct .skp file import.
  • Optimized Direct File Import:
    • Supports compatibility between materials from directly imported files and synchronized models.
    • Supports integrating Two-point Perspectives and more sky & environment settings from directly imported .skp files into the Scene List.
Great updates but i think you need to improve the AI Enhancement and make an upscale on the AI Enhance that will improve the quality more than any time.
Amazing! However, it would be great to include the release dates for each country, it helps keep us from dying of anxiety.
Team, another huge round of thank yous and congrats for continuing to enhance and expand this amazing program, cheers to you all for such dedication and hard work :blue_heart:
Thanks for the hard work you all I can’t wait to try all the new functions.
Big up !!!
What is new in the Teams edition for 3.0?
the app is very good
Hello D5 Team,
i haven’t been offered an update to 3.0 yet.
Is this normal?
Germany
Bye
Andreas
Hi Andreas, manchmal passiert mir das auch: Ich öffne den D5 Launcher, gehe links auf Workflow und dort sehe ich Update.
Hello Mirso.xhaferi,
Thanks for the information.
As you described, I have been trying it over the last few days.
I tried again this morning… and what can I say… it still didn’t work.
Bye
Andreas
Nice upgrade.
But I really don’t understand why the Image to 3D can’t be used locally on our Workstation.
An option / flag to use this kind of feature on our hardware has to be considered baseline in D5.
The result isn’t always perfect so you waste credits over credits before finding a usable 3D asset.
You’re not paying for a usable guaranteed 3D object, but seems more like gambling for a feature that in fact has to be considered baseline for who’s already paying the monthly / annual subscription.
Running the AI on a server is clearly costly for the D5 team, let the Users and customers paying theirs own electricity bill and use this kind of feature locally.
Hi, another Germany-based user here. I can’t upgrade to 3.0 yet either. I understand that it can take some time until the update is available worldwide, but can anyone say when Germany/Europe is due?
  • Mattias
A post was split to a new topic: Issue after update the latest sketchup livesync
@a.drexler @mattias.svensson Hi, If you’re currently logged in with a Team account, you won’t receive the 3.0 update prompt yet.
Please try logging out first, then log in again and make sure to select a Personal account, the update should appear after that.
Hello LiaHuang,
Unfortunately, it didn’t work.
Any other ideas?
Bye
Andreas
Looking forward to trying it all out.
Can this version use Path Tracing on AMD graphics cards yet?
and AI Render stuck at “Waiting”. Is it because I couldn’t upgrade to the new version?
