Plusieurs bugs et plantages avec D5 Render 3.1
Title: Multiple bugs and crashes with D5 Render 3.1
Since updating to D5 Render 3.1, I’ve encountered several major issues that ultimately forced me to revert to the previous version.
1. Arrow keys no longer work
The four arrow keys on my keyboard no longer function at all in D5 Render 3.1. They do not respond when I use them to navigate the scene.
2. Uncontrollable movement with the ZQSD keys
I also encountered a bug with the ZQSD movement controls.
When trying to move forward, the camera would randomly alternate between moving forward and backward while I was holding down the same key. The movement no longer matched the input, making navigation unreliable.
3. Graphical glitches and crashes with the AI Assistant
I also have an issue with the AI Assistant window used for applying effects or enhancing renders.
When I open the AI Assistant window, square artifacts appear and flicker throughout the interface.
The problem becomes even worse when I resize the window. The interface starts glitching heavily, significant lag appears, and D5 Render may eventually freeze or crash completely.
These issues only started after updating to version 3.1. They make the software very difficult to use for production work, so I decided to revert to the previous version, which is much more stable on my system.
System Configuration
  • Operating System: Windows 11 Professional
  • Windows Version: 10.0.26100 (Build 26100)
  • CPU: Intel Core i9-13900KF
    • 24 cores / 32 logical processors
  • GPU: NVIDIA GeForce RTX 4090
  • Graphics Driver Version: 32.0.15.9186
  • Memory: 128 GB RAM
  • Motherboard: MSI MPG Z790 EDGE WIFI
  • BIOS: American Megatrends H.50 (April 18, 2023)
  • Architecture: 64-bit desktop (UEFI)
  • Display Resolution: 3840 × 2160 @ 59 Hz
  • Affected Version: D5 Render 3.1
Are these issues already known? Is a hotfix or update planned to address them?
Hi @r.deloupy
I’ve translated your post for everyone to understand and see.
Most of the issues that you’ve reported are fixed in 3.1 Hotfix version, and currently it is still in grayscale release. The official release will just be around the corner and if you’re prompted to update to it, please proceed and let me know if any of the issue persists.
Thank you for your reply and for translating my post.
I have currently gone back to the previous version because D5 Render 3.1 was too unstable on my computer. I will wait for the official release of the 3.1 Hotfix, install it when it becomes available, and test the reported issues again.
I will let you know if any of the problems persist after the update.
Alright, Thank you!
Hi Clov,
Will the hotfix allow the arrow keys for navigation again? On previous versions I was able to at least remap the keys but the up and down arrow is now locked to a menu / list navigation.
Hi @adcdesign1
No, the up and down keys are locked to the navigation for 3.0 and 3.1
  • May I know which specific version you were able to remap these keys in?
  • Do you prefer having these keys instead of the WASD?
I am unsure of the version. But I was definitely able to either remap them, or one of the presets had them. I remember distinctively because I was happy to revert back to how I navigate in enscape and the only issue I had at the time was getting the middle mouse button to act as pan. Now in this latest version I have the pan working but the arrow keys can only map left and right.
I absolutely would prefer the arrow keys for navigation. I am not a gamer and never used WASD. I know the arrow keys have been requested in the forums in the past.
Hi @adcdesign1
Thank you for your feedback. We will consider this and, hopefully, add a setting to allow arrow keys instead of WASD.
