[Hot Issue] Frequent crashes in D5 Render during normal use after update to 3.0.0 & 3.0.1
Hi @gusrobatto
Thank you for sending the Google Drive link — we have received your D5 scene zip file.
We will begin reviewing the files and will update you once we have feedback or further steps. Thank you for your patience.
Hi @tomlaremin
Thank you for your patience and I sincerely apologize for the inconvenience caused. We haven’t identified a definitive root cause yet, which is why we are asking for more details so we can investigate properly.
Could you please help by providing the following information?
  1. What exact version of D5 Render are you using?
  2. Did the crashes start only after updating to this version?
  3. Are there any error prompts or messages before the app closes?
  4. Does it crash on new empty projects, or only on specific files?
  5. Does it happen randomly, or when performing a specific task (e.g., rendering, editing materials, syncing, etc.)?
  6. Could you share a screenshot of your D5 system info?
  7. While working on the project, does your VRAM usage exceed 80% in Task Manager? If it spikes that high, it can trigger crashes.
Could you also please collect your log files? Send them to support@d5techs.com, tag me in the email and include a link to this forum thread for reference.
Remote troubleshooting is still available, and it would allow us to check your device directly and gather deeper diagnostics. If you are open to it, please let me know your availability so I can add you to the queue. :pray:
Hello @ela @perspectivaavs @merlin.bartholomaeus @gusrobatto @tomlaremin @daniele
I would like to share my concern regarding the ongoing crash issues with D5. In the support forum, the team often asks the same questions repeatedly, and even after providing the requested information and log files, we still have not received a clear fix or solution.
These issues are now seriously affecting project timelines. As professionals using D5 for client work, stability is very important. Even after paying for and using the Pro version, many of us are still dealing with frequent crashes and unresolved problems.
It would really help if the team could provide a stable solution or patch soon. Alternatively, is it possible for users to roll back to a stable version such as D5 2.9 or 2.10, which worked reliably before?
Another concern is that with each new version, the lighting settings and scenes change, forcing us to rework our projects almost from scratch. This adds a lot of extra time and uncertainty during production.
We appreciate the development of new features, but stability and reliability are equally important for professional workflows.
Thank you.
The way this is beeing handled is turning into a tell tale sign of “you get what you pay for” i fear. paying the extra for D5’s major competitor before i made the switch, at least you had a team of tech guys in support that would go out of their way to help you, no matter what time it was.
I am running wild and losing my nerves with my deadline tomorrow. paying for a pro subscription for a program that crashes every five minutes is unacceptable.
please just give us a link to an earlier version befor this started happening. I can only find a link to version 2.9 which basically lacks all the AI features like inpainting or effects that I would desperately need. It must surely be possible to just provide us with a link to 2.9.5 or 2.10 somehow?
your help would be greatly appreciated, Thank you.
edit: just found the old versions here, in case anyone might still need them:
I’m not sure but if you’ve been working on a D5 file from 3.0.0 or 3.0.1 wouldn’t reverting back to a previous version open up another can of worms in addition to adding a new set of problems to fix including lighting, materials, atmosphere, etc?
Today I got two random crashes already. This last one was while rendering and working on a model in Sketchup at the same time. I still suspect there might also be a problem with LiveSync.
I don’t know what’s going on. I’ve grown to like D5 Render but with all these crashes with no end in sight that’s come into question. At the same time I really don’t want to have to go through the learning curve of replacing it with Twinmotion or at this point even Lumion. In any case, I need to do something about these crashes because I am in no position to have to deal with this on a daily or hourly basis.
I don’t want to revert to an older version. I’m a monthly subscriber and expect to get the latest software from D5 and not have to go back to a used car. These crashes need to be fixed soon because this is not sustainable and will also harm D5’s reputation.
Hi @vineeth82kumar
Thank you for sharing your concerns. Please rest assured that the team is actively investigating the reported issues and working toward improvements.
You can download the historical versions of D5 from the link below and install a version that worked more reliably for your workflow.
Thank you again for your patience.
Hello @gusrobatto ,
What you just mentioned is so true, paying for pro version and rolling back to older version and again dealing with latest version files in older version is a tedious and time consuming task.
Hello @ela ,
Thank you for your replay. If i reinstall lower version. Will i loose my library, favorites , custom materials etc
Hi! i already answered those questions in the previous topic i opened before you merge it here. About point 7, which hadn’t been mentioned before: in the file I was talking about, which is very big, yes, I’m probably exceeding 80%. I have an RTX 5080 with 16 GB. That said, I’ve always exceeded that and have never had these kinds of problems.
On the other hand, I was just working with a very small file and it also crashes, so no, it’s not because of that. Needless to say, this didn’t happen in previous versions.
Hopefully you can find the issue soon
Still getting random crashing. Still experimenting with settings. Sad really. I don’t even want to use D5 Render at this point.
Hello @ela @perspectivaavs @merlin.bartholomaeus @gusrobatto @vineeth82kumar @daniele
I think I may have found what is causing the crashes. As I suspected, I believe it is related to an internet connection issue.
I used D5 all day without any crashes and couldn’t understand why, until I realized that I was using it without being logged in. As soon as I logged in, it crashed again almost immediately.
If this is indeed the cause, I hope this information helps the developers fix the issue. As a recommendation for others experiencing the same problem, I suggest trying to log out and work that way to see if the crashes stop.
I know that users with the Pro version will see “Pro only” watermarks on some objects, but I think it’s still preferable to work with those watermarks rather than having the program crash unexpectedly every five minutes. If needed, you could simply log back in when it’s time to render.
Until an official fix or patch is released, this might be worth trying. Internet connections are never perfectly continuous; there are always tiny micro-interruptions lasting milliseconds, and it would make sense if that could cause crashes at random moments, which might vary depending on the day or time.
I hope this helps. It has worked for me throughout yesterday and today.
Best regards.
Hi @vineeth82kumar
Reinstalling a lower version of D5 should not cause you to lose your library, favorites, or custom materials. However, if your project uses features available only in version 3.0, you may encounter limitations when opening it in an older version.
In such cases, a prompt window may appear notifying you that certain features are not supported in that version. Alternatively, those features may simply disappear. Additionally, assets introduced in newer versions may not display correctly in older versions and could appear as white boxes.
Thanks Tom.
I’m afraid to say anything yet but turning off Turbo Mode in my bios seems to have done the trick. It’s for my Asus Z590-E motherboard.
BIOS: Advanced: CPU Configuration: CPU - Power Management Control: Turbo Mode: Disabled
Now watch. It’ll crash on me any second now. :nerd_face:
Perhaps there are different work arounds for other people.
It’s definitely Turbo Mode on my end. I’ve been working crash free for a couple of days with it off but this morning I updated my BIOS and it turned on Turbo Mode. I thought to give it a shot but it crashed D5 within 5 minutes. Trying to tune other things like tweaking XMP settings for RAM. Won’t make that much a difference. As for the cause of what appears to be a Turbo Mode bug on my end with D5 is unknown to me at this time. Same thing happened years ago.
Turbo Mode is like an easy form of overclocking where it raises the CPU speed within limits above its rated speed. My CPU (i9 10900K) is rated at 3.7 GHz and with Turbo Mode off it stays planted below that rated speed. With it on it will rise belod 5.0 GHz depending on load. The only issue with Turbo Mode on on my machine is with D5 Render.
If it crashes after this post I’ll let you know. :rofl:
@gusrobatto 100% true, if you have a Intel processor or certain motherboards it’s called “Intel turbo boost” I did what you said and it’s been 2 days without crashes so far. “THANK YOU”
There appears to be quite a few bugs with version 3.0.1 - while I’ve not recently experienced silent crashes, I’ve noticed a distinct drop in D5’s ability to handle large complex models (circa 8B faces) which is no different to what I was working on when version 3.0.0 was released and previous 2.11 and earlier versions. Some key things I’ve noticed and some momentary (yet less ideal work arounds).
When syncing large linked models from Revit into the D5 workspace there is a functional limit to the size of models its able to sync before crashing, however if you export the model(s) as a .d5a file I’ve managed to load all models without crashes occurring, this is less than optimal as in version 2.11 I was able to load all the same models flawlessly.
As mentioned earlier in the thread, materials have been appearing as white after reopening the D5 project (in my specific use case Grassland 03 was one of the main offenders which still hasn’t resolved - Base colour map icon was displaying initially as a white square, recently its reverted to a duotone grey square but unfortunately as far as I’m aware there is no way to reload the missing D5 base colour map.
Stability when rendering videos at 30fps, 1080p and approx 1min in length have on occasions crashed when rendering the full video (not an image sequence) - my assessment on this may in part be due to the complexity of the scene being rendered at the time of the crash (high poly count, lots of vegetation etc) the fact still remains this is a significant downgrade from version 2.11 which was much more stable from my experience.
This has significantly impacted deadlines and output for jobs I’m working on and would hope to see a more stable hotfix published soon.
Hi @everyone
If you still encounter “the occasional crashes after updating to 3.0.1”, please try to
  1. Roll back your graphics driver to 581.29 version. You can find it and download it here: Download The Official NVIDIA Drivers | NVIDIA
  2. Turn off ‘Turbo Mode’ in BIOS as @gusrobatto suggested
By the way, when you’re running D5, do you have any modeling software or D5 Lite running at the same time?
Hi @gusrobatto and everyone,
I wanted to provide an update regarding my recent experience with D5 crashes.
After extensive communication with D5 support and a review of my project files, their final assessment was that my current GPU (RTX 3060 Ti 8GB) lacks sufficient VRAM to handle the project’s complexity. They recommended upgrading to a GPU with minimum 12GB of VRAM, which currently costs approximately €1,000+.
I found this assessment unsatisfactory, especially since many users with more powerful hardware are facing the same issues.
Before committing to an upgrade, today I decided to test the “Turbo Mode-off” settings suggested by Gus (I am also using an Asus Z490M-Plus motherboard with a I9 109000@2,80GHz CPU). I am happy to report that I have worked for nearly 5 hours straight without a single crash (both actively working in D5 and leaving in stand-by).
While it may be too early to claim a permanent fix, this adjustment seems to be working for me effectively so far, so I highly recommend others facing similar issues try this setting before investing in new hardware or try anything else.
Gus, man, I’m not sure how you discovered this, but thank you—you’ve been a lifesaver!
Thanks Daniele. Something I figured out about 3 years ago with D5. Right now I’m experimenting with Turbo Mode on but I set Asus Multicore Enhancement to Disabled - Enforce All Limits. Just fired up D5 Render and I’ll see if it crashes. Looking for a workaround to keep Turbo Mode on.
Setting
ASUS Multi-Core Enhancement (MCE) to "Disabled - Enforce All Limits" forces your CPU to adhere strictly to Intel’s official power, current, and thermal guidelines. This prevents the motherboard from automatically overriding manufacturer specifications, typically resulting in lower power consumption, reduced heat output, and standard factory performance levels. It is the recommended setting if you prioritize system stability and longevity over maximum benchmark scores.
Took 10 minutes longer to render 6 scenes with Turbo Mode on with Disabled - Enforce All Limits than with Turbo mode off with MCE on Auto. I didn’t test overall performance like running Sketchup and D5 at the same time.
