**D5 Render Version:2.6.1
**Graphics Card:geforce rtx 3060
**Driver Version:546.01
**Issue Description:d5 render is getting installed but after that when i try to open the application it pops up and then closes.
Hello! First, I suggest you can update your video driver to the latest one. Secondly, please check if any antivirus, firewall or other software is preventing D5 from running. You can also try to run D5 as admin. For more details, please refer to this post. Crashes/Restarts/Fails to Load - Get Help / How to - D5 RENDER FORUM
i updated everything but still its the same
Any solution to this??
Hello! Sorry for your issue. Please send you log file to us and we will check it. This post shows how to collect logs. D5 Support Tool - Get Help / Tech Support - D5 RENDER FORUM
BTW, Please note that the power supply you are using is sufficient to support the D5. Please refer to this posting for more information on this. System Requirements for D5 Render
Also, please check your RAM frequency, too high RAM frequency may cause crash.
