AI Post-processing not working
Hey guys, I’m working on some images and the AI Post-processing seems to have stopped working.
I’m trying to use the AI Enhancer specifically, but the AI Style Transfer is also not working. So it’s an AI Post-processing problem I think.
I’m doing as I always do, but when I click on the big purple button “AI Enhancer” after setting up the weight, it loads for a bit but nothing happens. It’s not my internet because everything is working normally here, it’s not the final either because I just created a brand new D5 file with nothing in it, and it’s also not working.
Is there a problem with the servers at D5? I know this is an online tool, so maybe it’s not an issue for me, but for D5.
Just thought of dropping this here to know if anyone is also experiencing this or if the guys at D5 have learned about this problem recently.
Thanks a lot!
Hi @oliver,
I apologize for any inconvenience this issue has caused. I tried using the AI Enhancer tool right now to check if this problem persists on my end (to check if server issues) and it seems that my AI Enhancer Tool, using the steps you have provided, is working with no issues.
Can you please let me know your email address and region? So we can check on our system, thank you so much.
Hey @Clov,
Thank you for the quick response!
I’m based in Brazil and my email is oliver@learnupstairs.com
I just tested again and same thing. It loads for maybe 5 seconds, and then goes back to the “AI Enhancer” button as if nothing happened. The Task tab doesn’t show anything either, only my past enhancements.
Appreciate the support!
Looking forward to hearing from you.
Thanks @oliver for the confirmation,
It seems that this issue persists on other users as well, I am guessing this is region-specific given that I am not experiencing the same issue. I have already reported and forwarded your information to our Server Team to check if there are anomalies.
In the meantime, can you please try using a VPN and see if this issue persists? Or try using another network if the AI Tool Works. Thank you for your patience and cooperation.
solved here! changed DNS to google profile
Thanks!!! That worked for me! Much simpler than I expected.
I just tested with a sample file and it generated the AI Enhanced image. Tomorrow I’ll use the files I was trying to work on before this error. I’ll come back in case it doesn’t work, but for now, it seems to have been solved.
Just curious, changing the DNS… would impact negatively my internet in any way?
For those with the same problem, Google’s DNS numbers are:
8.8.8.8 and 8.8.4.4
For Windows I found this quick tutorial that helped me get to the correct place: https://www.youtube.com/watch?v=9BD264pKWzc
Just note that I think it will vary a bit depending on if you’re using IPv4 or IPv6. I’m not sure though.
Hi @oliver @financeiro
Thanks for the update on your situation and how you were able to discover a workaround.
Hello, I am facing the same problem now and I changed the DNS following the attached link but there is nothing changed and the problem is still there. The purple butten is loading without any results.
Hi @maria.ishac.awad
I apologize for the inconvenience this issue has caused.
  • Did this issue occur in the previous 2.9.1 Version?
  • Which specific AI feature did you use? Have you tried AI Style Transfer or Inpainting and see if these features are also working?
  • Have you tried connecting to another network? Or perhaps using a VPN? Please try and see if there are any differences.
  • Please provide us with your email address and region.
I have same error.
I use AI Style Transfer. I’ve already try to change the DNS, but dont works.
isoliev2128@gmail.com region, Central Asia, Uzbekistan
Hi @isoliev2128
I apologize for the inconvenience. Can you please try to use the AI Tool right now and see if it’s working normally? We recently had some server issues which have now been repaired. Please let me know. Thank you.
Hi, I tried, but dosn’t work.
Hi @isoliev2128
Does this problem occur after the 2.10 Update? Have you tried reverting to the 2.9 Version and seeing if it works normally?
Please whitelist the IP Address that I have sent to you via Direct-Message.
Screenshot 2025-03-25 205957
Hey guys, I have same error in D5 new updates
in previous updates there were no problems when i try Ai enchancer
Thanks a lot!
Hi @myfenje
  • May I know if connecting to another network helps or if there are any differences? or perhaps you can use a VPN?
  • Can you also provide me with your email address and the region you are in?
  • And lastly, please whitelist our IPs, I will send it to you via DM.
Hi everyone
If any of these suggestions are not working:
Then, please try this:
Hi Clov, I’m having the same issue. How can I revert back to the 2.9 version? I haven’t been able to find the download anywhere on the website.
Hi @snowflakes588
Have you tried setting the Time Zone to automatic? If doing so, does not resolve the issue please whitelist our IPs.
