Is it that D5 only crashes every time the AI Atmosphere Match feature is used? Does D5 still crash if you open it normally without using this feature now?
Does this issue occur in all scenes or specific scenes? If itâs convenient, please send your logs to support@d5techs.com and attach a link to this post. You can refer to this post to learn how to collect logs: D5 Support Tool
Alright, so the reference image was basically from the randomize category, does the crash only occur to this specific file? If so, can you share us this file? You may send it to support@d5techs.com and have it titled 2.11 Clov-Forum AI Atmosphere Match
Can you also confirm which 2.11 build you are using?
Additionally, Iâm also curious as to your VRAM Usage while using D5 and while using AI Atmosphere Match. Please open your Task Manager > VRAM while opening this file and doing the exact operation, then send the image here.
Thanks for these images, but this was not what I requested, but rather the log file
Please check the image that I have attached. There is an arrow pointing to âCollect Logsâ. After generating, it will redirect you to the logâs location. Thanks
Thanks for sending these log files, but may I know why there are so many of them? Are they from different devices, or did you just generate them 5 times?
I really donât recommend posting your log files publicly since they contain important and personal information, but of course, if you donât have any problem with that, then no issues~
HelloI generated it from each sheet, I didnât know what all you needed.Iâll ask, is it possible for you to connect to my computer and solve it? It seems really time-consuming to me. Iâm still awake. Itâs already 0:25 here.
