D5 Render 2.4
RTX 2080 Super
Driver 528.24
VR Controller buttons not responding. Using HTC Vive Cosmos. Running Vive Console, then Steam VR starts when I open D5. So the VR is up and running ok, and I can look around and see my pointer with the footprints, but when I pull the trigger on either controller nothing happens. The pointer is moving around when I move the controller too. I just can’t move myself around the scene. Did a controller test in Steam VR and all the buttons work ok.
Hi mate, to confirm, the trigger of controller on the right hand cannot work? If you work around with the device, will you move in the scene?
How to use VR (virtual reality) beta in D5 Render - Get Help / Tech Support - D5 RENDER FORUM
having the same issue d5 wont detect the controller movements
Have the same issue. Controller buttons on valve index not working.
