Latest 2.6 with no hotfix (where ca I get it?)
Nvidia RTX A5000
Latest
All bikes assets are white-no texture all of a sudden, Installed over the current version dowloaded one. In vain.
PS
Not all three
Hi ac1
If you still have version 2.6 D5 and have this problem, you need to update it with the new version 2.6.1, it seems to me that in this version they have solved the problem. But Oliver from the Team explained, it seems like 9 days ago, how to solve it with version 2.6, but he said that the new version mentioned above solved the problem.
What I wrote is not only a problem with the D5 library but also that the objects that did not load the textures. But I think if you also updated then there is something wrong.
Hello! Currently 2.6.1hotfix has been released. Open D5 and you will see the update promoted. When it comes to your problem, if only these three bikes are missing their textures, but all other objects are displaying normally, then I would suggest that you find the location WorkSpace\content\model and search for the name of this bike and delete the entire folder where the bike is located. After this, you can re-download this asset from the library and it should have the textures.
