I am making my first project, everything was going well until now that suddenly it hangs and throws the “TDR” error.
Hi! To solve the TDR problem, please do what the pop-up says. Run D5 Render as admin (right click the icon, select Run as administrator). Then reboot your computer.
For RTX 3090 Ti Graphics Card, your PC performances are so strong that the RAM (which is 32 GB) may be not enough, you are recommended to have a 64 GB RAM.
Hi, thank you very much for replying. I have tried doing what it says in the popup window, but the problem still exists.
You are welcome~
- Did you reboot the computer? Because it is a key step. If you do not reboot the computer, then the settings you made will not come into effect.
- And you said that the problem still exists. Do you mean the TDR pop-up window still pops up or it does not pop up but the program still crashes when running it or it just hangs?
- Please run the support tool and then send me the log file to rubyliu1107@gmail.com.
I have the same Error, my pc specs are RTX 3090 ti, i9 9900k, and 48 GB Ram.
