Stop running after loading the scene
Hi everyone,
I’m facing two problems that I think both have the same root cause
  1. when I open version 2.3.4 the maximized window doesn’t fit my screen.
  2. when it opens it stops running after a while and closes the program without any error messages.
    note: this two problems were not found while using the 1.4 version
    here is an attached video that shows the problems
thanks.
Screen Recording (11-6-2022 4-22-06 PM).7z (3.8 MB)
Hi there, please refer to the causes and solutions mentioned in this post:
If the above solutions do not solve your issue, please follow the steps in that page, then send the exported log file (which is called zziplog) to support@d5techs.com with problem description.
Thanks
Lia
thanks, Lia
The problem was solved when I made the program run with a low-quality display mode
it seems that my graphics card (8GB RTX) is not strong enough to run the program with high-quality display mode.
