Release notes | D5 LiveSync for Rhino
Ver.1.1.3.0016
Release date: 20251117
Feature Adjustments
  • Removed support for parallel projection mapping (to be reintroduced in a future update)
Fixes
  • Fixed an occasional crash caused by specific scene linkage
  • Fixed a crash caused by conflicts with Grasshopper third-party plugins
  • Fixed an issue where the ReplaceBlock command did not work
Ver: 1.1.2.0005
Release date: 20251104
New & Optimization
  1. Added support for two-point perspective projection
  2. Added support for parallel projection
  3. Optimized LiveSync performance
Fixes
  1. Fixed an issue where some large scenes turned black or displayed artifacts when synced to D5
Ver: 1.1.0.0002
Release date: 20241025
New
  1. Added ‘Export’ function, supporting export by selection and export grouped by layer structure
  2. Added single send option
Optimization
  1. Optimized the plugin installation process to resolve issues where the plugin could not be found after installation due to insufficient permissions
  2. Optimized the mapping logic for transparent materials
Ver: 1.0.0.0029
Release date: 20240703
New
  1. Supports LiveSync for Rhino
  2. Supports SubD Tools, mesh edit: curve piping, thickness, edge softening, etc.
  3. Supports Rhino 6.1 and later versions, D5 Render 2.7 and later versions
Optimization
  1. Improved the initial connection speed
  2. Optimized material mapping
  3. Optimized handling of object within blocks
Ver: 1.1.0.0002
New
