hello everyone! I have a problem with update 2.8. update failed try again. please help me
Sorry for your issue. Can you update successfully now? How’s your internet speed?
If the normal setup fails, it may be due to unstable network, you can try to turn off the firewall, vpn and antivirus software before installation. You can also try to reset or switch the network. You should have successfully installed via the full installation package, which is also fine and can be used in case of a weak network. Hope it helps. ![]()
thank you you realy help me!!
Can you update to 2.8 successfully now? ![]()
