Hi, try increasing the processing field distance in Properties. Usually if I remember correctly it’s 1000 out of 50.
Good work
Thanks for reaching out.
Currently, the presence of two mirrors directly opposite each other when viewing from specific angles can lead to anomalies caused by multiple light bounces, which is a known issue at the moment.
Can you describe the problem in more detail? Is this the case for both preview and output? What version of D5 are you currently using?
Regards
Good Day! Thankyou for the response.
Hello, Good Day !
The problem while seeing in the output only, in the preview it is not visible. I am using D5 V2.8.0.0469 only, last updated version.
Thank you for the updates.
For now, this issue should be within the expectation because there are fewer times of light bounce in the preview, while the outputs will be more accurate. Thanks for your understanding.
Cheers.
