Mirror not Reflecting light source
Mirror is not showing the reflection of the rectangle of light or any other light when the option to make the reflection visible is activated
Brasileiro
tem algum forum no brasil sobre D5 Render
ou Grupo
Hi @marco0aho
Can you send us a screenshot? I have tested it on my end, and it seems to reflect the lights. Have you enabled “Show Light Shape”?
Tem alguma ideia de que possa ser
Hi @marco0aho
I think you’ve posted your images and reply on the wrong forum topic. Please refrain from posting your replies to the wrong forum topic, as it may cause some confusion. Thank you for your understanding.
https://forum.d5render.com/t/d5-livesync-for-sketchup-2025/55050/4?u=clovisbolasco14
segue uma imagem que mostra o que esta acontecendo
follow image with the problem
In the common view it appears but when you render or use the F4 ACCUMULATE function it does not appear.
Thank you for these images,
I have successfully transferred your replies here. Anyway, may I know which material template is used for the ceiling? We don’t recommend using Sub-Scattering Material as it has a known issue with reflections. You might want to try change the ceiling material and see if there are any differences.
Thank you.
I’m Brazilian and I’m using the translator
but it’s like this before the update it reflected the rectangles of light in the mirrors
and on the ceiling it has the color of plaster and a ceiling light with a rectangle of light
I just wanted the light to turn on like before when selected to turn on
Sou brasileiro estou usando o tradutor
mas é assim antes da atualização ele fazia nos espelhos o reflexo dos retangulos de luz
e no teto tem a cor de gesso e um plafon com retangulo de luz
so queria que a luz ligace como antes quando selecionada para ligar
Hi @marco0aho
Alright, no worries. As I have mentioned, have you tried modifying the ceiling material to a different one? Please try and see if there are any differences. Otherwise, we may need to proceed to collecting your D5 File. Thank you.
sim ja modifiquei fiz varias mudanças abri ate arquivo novo sem nada para fazer o teste
Yes, I have already modified it, I made several changes, I even opened a new file without anything to test it.
Alright. Can you send us your complete D5 File? You may send it to support@d5techs.com and have it titled ‘Mirror not Reflecting Light Source’
Please zip your file first, then send it to us via WeTransfer or any platform. Thank you.
Meu projeto também deu um erro parecido. Ele reflete o background, mas não o projeto em si.
Hi @camilypeixotodejesus
I apologize, this is currently a known issue. :man_bowing:
You are talking about mirror problem from 22/ to 26 - and also you don’t do nothing with problems ! best to tipe a known issue
 :confused: - also mirror in mirror - tipical stuff in interior - end tunel !~
