Light shape doesn't show through water reflection
Hello. I would like to give feedback on this water issue where the light shape doesn’t appear through the water as you can see in first and second images. It becomes invisible. And on that note glass through glass reflections are quite bad as the third images shows, even with pathtrace.
Hi @leonardorgauer
This is currently a known issue. For now, you can use Emissive material as a temporary replacement.
Will do that trick, thx!
