There can be several different reasons for errors related to DLL files. For example, malware corruption on the computer, damaged Windows registry, d3d12.dll file being deleted or misplaced, application errors, etc. Generally, you can try the following methods to resolve the issue:
Solution 1: Try a clean installation of the graphics card driver and change a path to install D5 Render
- Update the driver through NV’s official software GeForce Experience, or download and install the driver by manually selecting the appropriate graphics card from NVIDIA’s official website
- Update the driver at AMD’s official website AMD Drivers and Support
- Update the driver at Intel’s official website Intel® Driver & Support Assistant
Manually search for drivers:
- According to your specific hardware configuration, please select the appropriate graphics card driver. You can find multiple versions of the graphics card driver on the official NV website, allowing you to download the corresponding version.
- Double-click the downloaded driver to install it.
- Retain the default directory, click ok, and wait until the decompression is complete.
- Select Install "NVIDIA Graphics Driver ", click “Agree and continue”
- Select ‘‘Custom’’, click ‘‘Next’’
- Click ‘‘Perform Clean Installation’’, click Next
- After the installation is complete, restart the PC
Solution 2:Try to fix the issue by DXR Repairment tool Download link
Original proposal jumps: Use the System File Checker tool to repair missing or corrupted system files
Instructions:
- Type “cmd” in the Windows search bar, right-click, and select “Run as administrator” to open the Command Prompt window.
- Type the following command and press Enter (this operation may take a few minutes to complete):
DISM.exe /Online /Cleanup-image /Restorehealth - Type the following command and press Enter:
sfc /scannow
Note: Do not close this Command Prompt window until the verification is 100% complete. - Once the sfc /scannow process is complete, the scan results will be displayed.
If the issue persists after following the previous steps, please provide a detailed description of the configuration and the troubleshooting steps you have taken in the dedicated support post on the forum. We will then follow up accordingly: Cannot solve the problem using the solutions provided ‘The program cannot be launched because of DLL errors in the system’ Thanks for understanding and support.
Yours Sincerely,
D5 Render
