AMD Ryzen 9 7950X 16-Core Processor
RAM 128 Gb DDR5
NVIDIA GeForce RTX 4090 (Gigabyte)
Gigabyte Technology Co. Ltd. X670 AORUS ELITE AX (AM5)
1863GB Corsair MP600 PRO XT (SSD)
931GB Western Digital WD_BLACK SN850X 1000GB (SSD)
Thanks for reply. We will check your problem as soon as possible.
Hello! Did you restart your PC after turning on the hardware-acelerated GPU schedulling? I think you need to restart you computer first. If this does not work, please send us your log file, we will check it for you. This post shows how to collect logs. D5 Support Tool - Get Help / Tech Support - D5 RENDER FORUM
I did not turned on the hardware-acelerated GPU schedulling, it is turned on automatically in Windows 11. I only checked it was on. And yes, I restarted my PC sevaral times.
This is the log file, one of two, te other one is to big toi send it, exced the 4 mb permited. I will try to compress it separately.
logs_AppData_Local.zip (2.2 MB)
service_20240124-105724.19984.zip (1.6 MB)
SupportTool.zip (6.1 KB)
Thanks for your logs, we will check it.
Here you have the log zip cpmplete.
Hello! We have checked your log. I think there may be some problems with your log, and we will fix it later in verison 2.7. But if you would like, we can also check your specific problem remotely now. You can make an appointment with me for a suitable time. We are available for remote assistance on weekdays from 10.00-18.00 HKT.
Hi! Yes, sure, I will be here all day.
Hi! We can provide remote assistance now. Could you use ultraviewer for remote?
I never used ultraviwer before. I just installed it.
OK,we will wait for you. You can send private message to me once you are ready.
I sent you a message.
Problem solved.
Hi , LunaLang,
I have almost identical system 7950X and a 4070 on Windows 11, and frame gen is not working … using the “beta” build… (2.6.1.0405),
arq.manuelmaza can share how you solved finally the issue?
thanks…
Sorry for your issue. I suggest you can send your log file to us and we will check it. If this could not help us solve your problem, we are also glad to provide remote support.
You can refer to this post to learn how to collect logs. D5 Support Tool - Tech Support - D5 RENDER FORUM
Thank you for your logs, we will check it. BTW, If it’s convenient, you can try using dlss 3.5 on a computer with Win 10.
thanks for support…
can’t test on a system with Win10 sorry…
will wait for response…
Sorry for your issue. Is it convenient for your to accept remote support? We can provide remote support from 10.00 am to 18.00 pm HKT on weekdays.
Hey, I had a similar issue with DLSS 3.0 after updating to version 2.5. What worked for me was doing a clean driver uninstall using DDU and then reinstalling driver version 536.67 fresh. Also make sure Windows Game Mode is turned on because frame generation needs that.
But here is something else I learned the hard way. Sometimes the problem is not your settings at all. It could be that a background app or a small glitch is blocking the feature. I had a friend who could not figure out why his frame gen was missing, so I used a free tool called UltraViewer to take control of his PC and look around myself. Turns out his Nvidia control panel had a weird profile locked in. Being able to see his screen directly saved us hours of back-and-forth texts.
Hope you get it fixed soon. Let me know if the clean driver install works for you.
