Hey guys, I have to admit that I´m a little frustrated. Today I bought D5 Premium. 1 hour later I experience that live sync does not work proper anymore. Seems to be the latest D5 Update causing this error.
In my loom you see what the problem is. Livesync stops working as soon as I try to orbit in D5. I even tried this with a fresh sketchup file. Same problem after a bit. Could you pls fix this soon? Without it working I have no use for D5.
Is it possible to get an download link of the D5 Version before the latest one? Seemed to be working fine here.
Hi, I saw on the video you posted that when you synchronize the D5 file you don’t save it, and then when you switch to D5 the reference file disappears. Try saving and see how it works.
Unfortunately, it did not work successfully for too long
Again at some point same error. Plus the message:
“The model association with the D5 Render has been broken, live sync abort”
When I close both Sketchup and D5, open it again, and try to resync all my applied materials are gone. I wasted hours of work already. Its quite annoying
Hi, I’m sorry, sometimes it’s a memory issue, if your disk is almost full it can cause these problems, then I don’t know the setup of your PC if it’s very powerful, if it uses all the capacity of the GPU. I talked about the topic with another colleague about filling the disk, proposing an alternative, using the layers of the graphics program. I saw that you use SKP, in that case you know when you do a job and then save it in D5 it creates a folder where there is all the reference data, in this case that folder takes up space, then you make corrections on your work and save it with another name so as not to lose the old one. In this case, when you synchronize again, you can’t do it with the old one but you can synchronize it by merging it, but you have to rename it and then you will have a new folder with D5 that takes up space on your disk. Instead, using the layers of your graphics program, i.e. like changing the furniture, but keeping the old one by turning on and off the layers with the same graphics files and the D5 one, in this way you don’t create any more MB or Giga space.
I hope this topic is useful for managing your work.
If your disk is full you have to empty it by putting your old works on an external disk, in this case you will have more capacity to manage your files.
HI
For me you are doing nothing wrong, but how many giga does your rtx 4070 card have?
You didn’t say this in the list, I only understand that you have 64 Giga.
Then you updated the card, then in your PC options you have done this!
Then I want to understand if you have 2 graphics cards, one from your PC system and the other which would be the RTX you have. Sometimes the computer gets confused with the cards you have to go to the NVIDIA options and make sure that it only uses the RTX 4070
I hope this way you’ll find out, otherwise you’ll have to wait for one of the staff, right now they gave a statement the other day that I’m on holiday
For my part, when I have time I make sure to help some colleagues ‘in my small way it is understanding to solve some problems’.
sorry for my English
That Open GL setting on your screenshot was set to automatic - i set it to the 4070 and will test again. Also adjusted the FPS like you said. Might be a thing.
Im afraid it wont help though. I mean my hardware is relatively powerfull and it should not be a problem at all.
The only setting in use I want to mention is the use of “Vertical Sync” in the programm based settings from NVDIA. I did this because when it was not activated I had screen tearing in the worst way possible.
so your settings have definitely done something. I could recognize that especially in reflections of mirrors. I also have the impression that the materials from D5 look somewhat different. So I tinkered around a bit again, and after about half an hour I thought we had the solution. Unfortunately, I was disappointed again shortly after. House disappeared again, D5 models still there. I have the feeling that the problem begins as soon as I start to load D5 models into the project after I have applied some materials. All in all, pretty nerve-wracking. I have now wasted 10-12 hours. Once the error occurs 1x, the file is useless. Even if I close it without saving, the error remains with the next opening. Sobering…
Really sorry for your problem. Did you use a SU model from cloud or server? If this problem persists, please send us your file (support@d5techs.com). We will check your files after the holiday.
Sketch up model coordinates issues after saving in different file name.
I had a problem syncing the same sketch up model after saving it to different file name. I already tried the option to replace, import and live sync the model in D5 Render, but the model is still in different location.
