D5 Render Will Not Open
**D5 Render Version:**3.1
Graphics Card: NVIDIA GeForce RTX 4070
Driver Version: 13th Gen Intel(R) Core™ i7-13700, 2100 Mhz, 16 Core(s)
Issue Description:“System environment error. Please follor the tutorial to resolve the issue, or contact customer service.”
Hi @fmccaffrey
Please send us the following:
Were you able to follow the suggested steps that are mentioned in our user manual? If not, please try the following steps stated in this link:
Hi, Thank you for your quick response. I have followed those steps in the past and again yesterday. I also do not see the “Manage Display Mode” in the NVIDIA Control Panel. I will continue to follow these steps more closely in the meantime. Thank you.
I will confirm I have tried everything in the link you have sent.
Hi @fmccaffrey
Just to clarify, this occurs to all files, right? Were you able to use D5 Render normally before? Were there any actions you have done, such as updates, that may have triggered this issue?
  • Are you opening a D5 File when you were checking your Task Manager? If so, it seems your iGPU is being used instead of your RTX GPU. If this is really the case, try disabling your iGPU temporarily and please ensure your monitor is connected to your RTX GPU
Another suggestion:
Disable CPU overclocking and XMP profile
  • Enter your BIOS settings and disable CPU overclocking, as well as any XMP memory profiles. Reset these settings to their default values.
If the issue still persists, please send us your log files.
Hi Clov,
I previously used the free version, but when I updated it, it started to not work. We have since decided to purchase it. After trying to re download it I continued to have the same issue. I will try you latest response next. If the issue persists I will reach out again. Thank you!
Hi @fmccaffrey
Alright, please do. Thank you.
Hi @Clov It’s been a while, and I had it working. And now it wont even open d5. only the launcher opens, and when I click new file it won’t open. I’ve routed the correct graphics card to be used and it still doesn’t work. I believe this is above my pay grade lol. I’m at a loss.
Hi @fmccaffrey
  • Could you please share how you were able to resolve this issue in the past?
  • Additionally, I’d appreciate it if you could let me know whether this problem affects all of your files or just specific ones.
  • Have there been any significant changes on your end that might have contributed to this issue, considering it was functioning well after our earlier conversation in the forum?
  • Lastly, were you able to try the suggestions I provided, such as disabling CPU overclocking?
I first updated the Bios, then I went to graphics settings and specified which Graphics card D5 should use. But now it has stopped working again. It effects all files. It doesn’t even open D5. Only D5 Launcher will open. I tried downloading the new update as well. I will have to disable overlocking. I didn’t try it because it was working.
Other then that, no specific changes.
Hi @fmccaffrey
Just to clarify, you’re still using 3.0.1, right? Since there is a similar issue after updating to version 3.1.
Can you regenerate your log files?
Hi @Clov
I downloaded 3.1.0 yesterday to try and see if that worked. Should I try updating Bios again?
I don’t see “Collect Log Files” on my window.
Found it. Hang tight.
Hi @Clov
I downloaded the logs and received the zip file. What is it that I need to do exactly?
Hi @fmccaffrey
Please click “Collect Logs” after it has generated the log files; your Windows Explorer should automatically open to its location.
  • Generally, it is located at this path C:\Users\xxx\AppData\Roaming\D5Launcher
Hi @Clov,
I downloaded the logs. What do I do from there? I need to get this working as I have a deadline, please.
This is the path that I have…
C:\Users\fmccaffrey\AppData\Roaming\D5Launcher\zziplog.zip
I have Windows 11 Pro and my GPU Driver Version is 32.0.16.1047
Hi @fmccaffrey
Please send it to me privately.
Hi @Clov,
I tried sending this via email yesterday.
zziplog.zip (2.6 MB)
