D5 render not starting,
D5 Render Version: Latest Version 2.11
Graphics Card: AMD Radeon RX 7600S
Driver Version: V31.0.14080.10
Issue Description:
I cannot open the models I created using the latest version (2.11) of D5. The files load until 99% as shown in the attached screenshot, but does not open. However, I am able to open the models I created using the older versions without any issue.
Hi @22rbid008
We apologize for the inconvenience. AMD-related compatibility problems have been a hot issue lately, and our team is still actively monitoring and investigating the situation. For now, the most reliable workaround is to roll back your AMD driver to the previous stable version, as the newest driver is known to cause loading failures, crashes, and usability issues in D5 Render 2.11.
This solution has worked for most affected users.
You may refer to our official forum post for the full workaround and the correct driver version to install:
[Hot Issue] After updating to the AMD driver (25.10.1), D5 crashes or becomes unusable
Once the driver is rolled back, your 2.11 models should open normally.
Please let us know if the issue persists—we’re here to help. :blush:
