D5 Render Version:
Graphics Card: RTX 3060 12GB
Driver Version: 32.0.15.7216
Issue Description: When trying to open a heavy file D5 stops at 97% and crashes, asking for more VRAM, however it is not using all VRAM available, I can’t even open the project to lower the resolution/quality
Hi there,
I apologize for the inconvenience this issue has caused. I will be linking you to a forum thread that I have created that talks about this issue and how to solve it. You may update me on this thread on the results after following the probable solutions that I have mentioned. Thank you.
Yes, it has already happened in other files that have already been won. After a certain time, this happens.
2. Out of Video Memory
—This issue is usually evident when you have used a lot of assets in your D5 Render file without proper asset management.
- Solution: If the file fails to open, please delete the ‘f2’ folder under your WorkSpace path and then reopen the archive. Once it’s open, refrain from updating the assets until you have lightened your scene file by deleting some assets, including procedurally generated vines. This will help prevent it from crashing again due to excessive video memory usage.
CURRENT ISSUE
We are currently monitoring an issue where some old archives opened in version 2.9 experience excessive resource consumption. We are working on fixing this in subsequent releases. In the meantime, please check your scene files for the following:
- Are there a lot of ‘procedurally-generated vine assets’?
- Is the drop feature for vegetation paths used?
If so, please optimize your archive accordingly.
