D5 crashes
hello , D5 crashes in 5 sec , does not open the portal my gpu is gtx 1080 , cpu i5 3570 and de nvidea and the nvidea controller does not recognize it to use?
Hi mate, What’s the version of D5 and your GPU driver? please also screenshot the system info. You can consider updating them if they are relatively old.
Also, You can refer to this blog for possible solutions:
Crashes/Restarts/Fails to Load - Get Help / AnswerHub - D5 RENDER FORUM
If the things above are ok, please send the logs to us for troubleshooting.
support@d5techs.com
How to collect logs:
HI thanks for anser , this is are my pc , and D5 my pc doesn’t use my gpu at all
Hi, can you change the path to install D5 and check the result? from the screenshot, it should be okay.
If still does not work, Please send the logs to us for troubleshooting.
support@d5techs.com
thanks yes that fix the problem
