**D5 Render Version:**2.3.4.0932
**Graphics Card:**RX6800M 12GB
**Driver Version:**31.012029.7019
**Issue Description:**Instalo el programa, cuando voy a abrirlo carga normal y pocos segundos despues se cierra, no manda ningun mensaje de error y segun el instalador mi dispositivo es compatible.
Hello, I saw your video driver is 31.012029.7019, which is released in November, and may trigger this known issue:
[Hot issue] D5 Render cannot open or get stuck at 15/85/99% #20221031 - Get Help / Tech Support - D5 RENDER FORUM
Please downgrade your video driver to 2022.8.1, then reboot your computer and D5 to see the result.
AMD Radeon™ Previous Drivers | AMD
If the problem persists, you can run the D5 support tool and export a log file(remember to put it into the installation folder of D5 before running it), then send the log file(zziplog) to support@d5techs.com for further troubleshooting.
Thanks,
Oliver
