Can't use the D5 asset because blocked by corporate security
I signed up for a trial and I tried to test before the trial ended
But I can’t access the D5 assets because I’m blocked by my company security.
So I asked D5 support and they told me to whitelist.
So I contacted my company’s security team and got whitelisted.
But still no go. How can I solve this?
Below is the whitelist that D5 sent me
Or I think it’s because the company IP is assigned manually, what do you guys think?
https://usa.api.d5render.com/
http://usa.d5render.d5cdn.com/
https://d5render.d5cdn.com/
https://usa-model-d5works.d5cdn.com/
https://usa-d5works.d5cdn.com
https://cn2.fusion.d5techs.com
https://cn.fusion.d5techs.com
https://usa.fusion.d5techs.com
https://cn.api.d5render.com
https://d5-asset-cn2.oss-cn-hangzhou.aliyuncs.com/
https://d5-asset-usa.oss-us-west-1.aliyuncs.com
Hi there, sorry for the inconvenience for this issue. May I know if your company is using a VPN?
Let me know if any of these helps. Thank you~
Thanks for the reply :smiley:
The ones you guided me to work fine, but I think it’s because the IP settings are manual?
We can’t turn off the firewall at will, it’s controlled by the company’s internal security.
Maybe it’s because the company has strong security?
3
Hi there, sorry I wasn’t able to get what you said, do you mean that the proposed solution worked?
May I also know your internet provider and the location where you are located? Also, have you tried turning on or using VPN and see if you can access it? You might want to refer to this link for further instruction, I suggest testing out these solutions. Please let me know if it works. Thank you so much
Why are the assets not displayed in the assets library? | User Manual (d5render.com)
No, the solution failed.
My internet provider is unknown.
My region is South Korea.
Can I customize my own address and port when setting up the VPN?
How do I set my IP to normal?
I think it’s because my company has strong security.
Can you send me the whitelist one more time to make sure it’s correct?
Hi regarding the VPN, if you ever decide to use one. You might want to verify if the VPN or proxy is turned on/DNS is normal.
As for the ports our team sent you via Email, I may need to reconfirm it again and ensure that it is the latest version. I will be updating you regarding this matter as soon as possible. Thank you for understanding.
We are not using a VPN.
but We have a separate address for the script in proxy setting menu
We can’t use auto-detect, it clogs up our internet at work.
(Only the set script address is available)
And our ip settings set to manual, When we change the
ip setting to automatic (DHPC), our company loses internet.
My company’s security policy prevents me from turning off the proxy, and I cannot use
IP auto-setup (DHCP) is not available
Is there any other way to access D5Render assets?
Hi, thank you for your update. I am so sorry for the inconvenience this issue has caused. Was there an IP Address sent by D5 to your email? If there was none, you might want to check your inbox here in the forum. If the issues persist, I will forward this issue to my team to assess your situation further. Thank you for being so understanding.
I finally got the issue resolved. :star_struck:
We had received an IP whitelist from D5 about a month ago.
and the whitelist was registered by our security team.
But it still didn’t work,
Yesterday we finally figured out why!
It was so stupidly simple,
we just turned off the Proxy button in Preferences within D5 and it worked.
Thanks for your help in the meantime :blush:
Hi thank you for sharing your solution, glad it was resolved~
