Thanks for your email. We will check it.
Hello! I have checked your issue again. I think your problem may be related to your Internet Service Provider and your region. You may want to check if you are currently using Lanet, an ISP that we have had feedback from users that they are unable to access our website and log into their accounts. We suggest that you try using a different service provider.
Hello! I use Triolan ISP and unfortunately can’t change it since my PC only supports cable internet.
Have you tried to use VPN? BTW, can you open myspace and log in on our website now?
Also, if you can, you can try contacting your ISP and ask if it would be possible to whitelist our ports.
Our ports are these:
https://usa.api.d5render.com/
http://usa.d5render.d5cdn.com/
https://d5render.d5cdn.com/
https://usa-model-d5works.d5cdn.com/
https://usa-d5works.d5cdn.com
Hi, I also have problems with login into the website, but as you suggested VPN helps with that issue, but inside the software, it doesn’t help.
I think you can try to contact your ISP to ask whether they can add our ports to whitelist.
Okay, I will try that, thank you for the help! Please also let me know if you were able to check my logs.
I am so sorry that we have not received your email. I think this is also a network issue. You can send your log to us by WeTransfer, one driver or Google cloud drive.
Hi all, this issue has been resolved with the new update. Thank you so much!
Hi! Really glad that your problem has been solved. Would you mind telling us how did you solve this login issue?
Hi! I didn’t do anything in particular, just updated to 2.7 version, when I saw that the website started working. I think your team managed to solve this by avoiding the russian server when logging in.
Thanks for update for your issue.
