Camera loosing their position after switching to viewport camera
D5 Render Version:
2.11
Graphics Card:
RTX4090
Driver Version:
latest
Issue Description:
cam_loss.zip (2,7 MB)
Switch between cameras, deselect camera and select it again
Hi @Smolak
  • Does this only occur in this specific file? I did a test on my end, and the issue is not evident. This is a video recording on my end: Unique Download Link | WeTransfer
  • Does this issue occur in this specific file only, or in all of your other files too?
  • May I know which 2.11 build you are currently using?
    2.11 Build Version
I’m using the same build. I tried new scene and the same issue :
D5_cam_issue.zip (2,1 MB)
Probably I know why this is happened. When only camera active box is selected it loose coordinates:
It probably works fine when not only active camera box is selected but camera object too :
I will try more tests.
I can confirm that this issue is related to situation if only active camera box is selected without selecting camera object.
Hi @Smolak
Still no replication on my end, even with selecting the camera box or not.
Log : zziplog.zip
I have RTX 4090 with latest studio drivers.
Scene :
D5_cam issue(1).zip (2,6 MB)
D5 Cam Issue.zip (772,9 KB)
Hi @Smolak
Thanks for sending the requested file.
