After updating to 2.1.0.0303, there were problems with models and their display
D5 Render Version: 2.1.0.0303
Graphics Card: 3080ti
Driver Version: 511.79
Issue Description: After updating to 2.1.0.0303, there were problems with models and display.
some models were not loaded, some were displayed incorrectly. after a flock of birds began to show problems with the display, I decided to inform you.
Before that, I completely reinstalled 5d to the new version and deleted the downloaded models before that.
At the moment I’m working and ignoring / deleting problematic objects, but the problem with birds appeared after reinstalling 5d.
cars seem to have ceased to disappear … only birds remained
some cars were not displayed correctly
bandicam 2022-02-23 14-40-09-868_1.zip (3.3 MB)
Bird flock display problem - bird particles caused flickering
Dynamic curtains don’t always render fully either. Sometimes the lower half is missing.
Look what happens because of flocks of birds…
Hello J, this is a known issue we will fix.
hello artikd, sorry for the inconvenience caused by this problem, in that scene file, did you replace old assets with new assets directly?
First, we want to confirm it with you, the problem happened only to this scene file, right? If you open an empty scene file then insert those same assets from the library, will it work well?
Second, Please show us the name of those assets or a screenshot of them in assets library. It would be good if you can compress the whole scene file and two logs files then send them to support@d5techs.com to help us solve this problem.
two folders:
  1. A folder called logs, in the installation directory of D5 2.1
  2. A folder called Saved, in C:/Users/your account/AppData/local/d5_immerse
good afternoon.
The problem is not permanent, I deleted those elements, resaved the scene to another save and reloaded the scene and then put the same assets (they were birds made by particles) everything works fine so far …
I just wanted to report this kind of instability…
the scene is working fine now, but I’ll send it to you anyway if it can be of any help to you…
Ok, thank you artikd, my email is ziyin.zhu@d5techs.com.
It is also our main aim to ensure the stability.
A post was split to a new topic: Grass displays incorrectly
