I have the same problem,
the grassmaterial01, also applies to 02 and 03, are displayed badly in a project. In other projects they are displayed correctly, as well as in new projects created from scratch.
I saved the problematic project with another name (save as), but the problem remains.
The re-saved project is It is smaller (3,3GB vs 2,7GB)
UPDATE:
I did some more tests and discovered a curious thing. When I move away from the center of the project, the bad brush turns into good. I remember the grass models that have (in my case) this problem and only in one specific project are GrassMaterial01, 02 and 03. This happens at a variable distance from the center in the four directions, from 40 to 90 meters approximately.
Regards
