[2.10 Hot issues] Puddle effect changed & Previous scenes become much darker
Following the release of version 2.10, two issues have been identified that are within expectations. Below is an overview of each issue, including its cause and the proposed solution. Thanks for your understanding.
:cloud_with_rain: Puddle effect changed
Following the 2.10 update, several users reported changes in the effect of puddle/snow within old archives, stating that the original effects can no longer be replicated, even with parameter adjustments.
Reason:
2.10 optimized the rain and snow effect, the current puddle distribution can not satisfy both the human viewpoint and the bird’s eye viewpoint at the same time. We will optimize it accordingly in subsequent releases.
Solution:
  • Manually adjust the parameters in the latest version to achieve a puddle effect close to the previous.
  • If you need the exact same effect as the old version, it is recommended to output the old archive with the old d5 version.
D5 History Versions: Download Historical Versions of D5 Render
Related Case:
Puddle Rain and Snow Problem (Ver. 2.10) - Get Help - D5 RENDER FORUM
:waxing_crescent_moon: Previous scenes become much darker
Some users reported that when opening old archives (with auto exposure enabled before) using 2.10, the scenes became much darker.
Reason:
2.10 adjusted the sensitivity of auto exposure to accommodate the new night sky effect (to prevent overexposure), which resulted in scenes with auto exposure in the original 2.9 version becoming darker in 2.10.
Solutions:
1. Continue to use 2.10:
  • Turn off Auto Exposure switch
  • Manually adjust exposure parameters
  • Update all scenes, videos and render queues.
2. Need to fully maintain the original effect:
Please consider rolling back to 2.9 version to finish the project:
Related Case:
2.10 updated, all my scene are significatly DARKER than previously with 2.9 - Get Help - D5 RENDER FORUM
Hi, after updating to 2.10
all scenes become much darker due to auto-exposure not working
tried turning on and off again,restart, etc didnt solve the problem.
no time to manually re-set every scenes+video path…
now rolling back to 2.9…
Hi @mj-sekkei
I apologize for the inconvenience. Can you send us your D5 Scene file? So we can test it on our end. You may send it to support@d5techs.com and have it titled ‘Clov-Forum Auto Exposure re-enabled not working’ or you can directly send the link of the file here in forum or in direct message. Thank you.
