Why doesn't the costom path show the object to select in the material id?
**D5 Render Version:2.11.1.0620
**Graphics Card:Nvidia RTX 3070
**Driver Version:32.0.15.8129
**Issue Description:Why doesn’t the costom path show the object to select in the material id?
Hi @artist.apps04
I have tried it on my end, but the assets that are in it seem to be included in the Material ID Channel.
  • Can you confirm if this only occurs with this specific asset? If so, let me know which asset was used
This only happens with asset local model because when using asset online model this problem does not occur and it only happens when using function with custom paths because I want to use asset local model.
Hi @artist.apps04
Can you send me the specific model so I can test it on my end? I tried it with an imported model, which is placed in my local library, and this is what it looks like.
I tried sending you the file I used as a wetransfer link for you to try
https://wetransfer.com/downloads/3627cd73b76c79b365c7cc0cc7e4814320251021025838/7290ac4ece49b7621777e9233e19e26520251021025918/c60f13
Hi @artist.apps04
Thank you for sending your files. The issue persists on my end with the file; we will further investigate this matter.
