I’ve never seen anything like this!
What kind of way is this to manage material files on the hard drive?
It’s incomprehensible and unmanageable for the user.
You can’t find anything, it’s a complete mess!
It’s impossible to find the texture used in a material to edit or check it.
What’s more, the right-click function on a texture “File Location” is always grayed out.
You can’t edit textures of materials used from D5 Asset Browser directly. Save material to Local and after that you will find it in your local folder. File location is for custom build textures.
In Cinema 4D built-in Asset Browser is the same. These predefined materials cannot be edited because they are stored in on-line database. You can edit them after moving to local storage.
That’s not true. Unless I’m mistaken, locally saved materials are in a non-editable .d5m format.
And if you save an object locally with its material, then the .jpg and .png files won’t open in any application.
I would like someone from D5 to explain to me why everything is locked.
I wanted to migrate from VRay/Vantage to D5 Render, but that hasn’t happened yet.
I was only talking about the possibility of editing textures, not objects.
With 3DS Max and VRay, i have no difficulty editing the textures of materials from the Cosmos library in Photoshop.
And there is nothing stopping me from converting an object from the Cosmos library for export.
I understand you correctly because I have the same problem now. I stored texture in local material and I don’t remember from where I get it so I lost access to it.
