I’m not sure what’s going on with the water reflection through the glass in this video clip. When the sliding doors are closed there is a bright reflection on the water and a bright halo around the plants in the foreground. When the doors slide open the bright stuff goes away. Rendered still images do not have the bright bits either.
Frame from video.
Still image.
hi, can u share d5 scene on wetransfer. i’ll check on my system, for what cause this reflection.
Hello, is this a preview video or a rendered result? Can you tell me which version of D5 you are currently using? If possible, I suggest you to send me the D5 scene file. You can either share a direct link or send it to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
