VIDEO bitrate
**D5 Render Version:**latest
**Graphics Card:**RTX 3070
Driver Version:
Issue Description: bitrate too hight, more than 160,000 kbps, 10 secs video = 200 MB size too much!
VIDEO BITRATE
I would like to know, if there is any way to low the kbps, in order to make renderingvideo times lower, and size not so big, thank you for answer!
Ok, I will consult the tech team then let you know the answer, thank u~
Hello, the tech team told me the bit rate is also related to the complexity and color of a scene file.
Also, if you want lower bitrate and file size, I think you can render MP4 format?
From the screenshot, you rendered avi format?
Best regards,
Oliver
Hi Oliver and thanks for answer.
I actually rendered video in MP4 format. Would be great that in future upgrades they add a tool that we can select the bit rate we want the video to render.
I have another big issue at the moment, related to images/renders.
I cant select aspect ratio(5:5 , 4:3 + preset size( 2k,4k,6k) Please help me to fix this, i need it very urgent, this was the main reason i wanted to upgrade to PRO acc.
Thank you, and best regards!
Hello Dans93, ok, I will let product team know this requirement.
Besides, with regard to the aspect ratio and size, since 2k, 4k, 8k are fixed, I kindly suggest you set 5:5 first then adjust the size. Otherwise, the UI may need to be redesigned.
Thank you so much! fixed now! :grinning: :ok_hand:
Best regards!
Hello dans93, you are welcome. Besides, I told our tech team that your mp4 has 166496kbps bitrate, which is very strange. They told me we may need to optimize this, and could you please show me some screenshots or send a sample of the video file?
If it is private, you can send me a link at ziyin.zhu@d5techs.com
we will look into this as soon as possible.
Sure. This are some screenshots. If u need i also can upload to Youtube and share link.
This is one video.
Screenshot_8
Screenshot_7
And this is other video.
198
Hello, thank u very much, our tech team told me we choose to get high quality video so the bit rate is very high. We will consider to add an option to control the bitrate(high, medium, low) in the future, thanks again~
hey thanks! i also would like to know how to use this settings:
asd
Is there any tutorial to know how to use it? Thank you! best regards!
Video - User Manual (d5render.com)
Hello, you can view the User manual, and we will release video tutorial after D5 2.2 comes out.
If you need further assistance, feel free to let us know.
Regarding a similar context. the video bitrate for the sequence in jpeg or png is only 30.
I dint even know that it was until i calculated all the frames by the time of the footage u know as there was no mention of it in the program.
I took a ref render as example.
25sec=751frames=30.04fps. Not exactly 30.
0.04 frames extra come then the footage becomes choppy upon compiling. Which results in jerking on playback of video after stitching of footage.
Please could you also provide an option to make 60fps png/jpeg sequence as well.
Hello, yeah, the fps of video and video sequence are same now: 30.
We are planning to add a new feature to control the video (sequence) fps, such as 24, 60, etc.
