**D5 Render Version: 2.1.0.0303
**Graphics Card: RTX 3090
**Driver Version:511.79
**Issue Description: Vegetation path was visible in the finished image!!??
**Screenshots/Videos Description: I attach a picture
**Steps to Reproduce (optional): Unfortunately, this error is not reproducible.
Hello D5-Team,
in a recent project it happened that the vegetation path was visible in the finished image!!??
In the attached picture you can see this grey stripe in the right part of the hedge.
After restarting D5, this error no longer occurred in the finished image.
Then again after a longer processing!?
Bye
Andreas
Hello Andreas, what is on the path? plants or other items? If this problem cannot be reproduced, could you please compress this scene file and send it to support@d5techs.com?
We will look into this issue, sorry for the inconvenience. Besides, it would be good if you saved that scene and remember the output resolution.
Best regards,
Oliver
Hello Oliver,
there are plants on the path.
The output resolution is 4K as .jpg.
Bye
Andreas
Hello Andreas, we checked the file and found that the line in your photo is not the path of path tools, but strange reflections due to the settings, I will explain that for you in private message since the project is your private file.
