[URGENT]Corrupt .drs file
D5 Render Version: 2.7
Graphics Card: RTX 3090
Driver Version: Nvidia Studio 552.22
Issue Description: The file appears to be corrupt.
I try to open the file, when I get to 99% the D5 screen crashes
I tried opening backup files automatically generated by the program.
I renamed the .bak file to .drs file
One of the 3 backup files I have opens, but it doesn’t let me save the project or change/modify the materials.
The backup project is virtually unusable.
Can someone help me?
It’s an important project that I have to turn in tomorrow
Hello! Sorry for your problem. Is it convenient for you to send your scene file to us? We will try to fix it. You can share a link here or send it to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
Corrupt files means that you have copied a DRS file and placed them outside the original folder… so what happened was u took a file or backup renamed it, then relocated it to somewhere in your drive or differenet directory folder…outside of its original location, what happens now when u try to open this file this message appears… REASON i know is i made same mistake too… few days ago… :sweat_smile:
BTW; what ever you do u wont be able to save this file… :joy:
Solution: go to your backup folder and rename the back-up file to -----> DRS extension name. then open it… (dont relocate this file) after opening you can save a new filename to whatever location u desire.
Hola, buen dia, disculpa, vi que has respondido a la duda de LunaLang, y al respecto tengo una pregunta, ¿como puedo guardar el archivo recuperado como uno nuevo?, lo que me paso, es de que cambie la extension .bak a .drs, se logro abrir y todo, pero…no me deja editar ni mover naada, el archivo esta en la misma ubicacion de donde esta el .bak, deberia de cambiarlo o que solucion hay, necesito ayuda :frowning:
Hi @pmay.25582
We don’t recommend that process to access your backups since this will cause a lot of issues. If possible, please revert it to its original state, including the .drs file.
  • If you wish to access your file’s history, you may go through the Recent Tabs > Right Click the project > View Version History
    version history
D5 Render Version: 2.10
Graphics Card: RTX 4060
Issue Description: The file is corrupted
Hi, I’m Alessandro
I’m writing to ask help with a problem that I faced yesterday.
I made a big mistake: I completely deleted the folder with the render file of my project. Now, I only have the backup .drs file, but I can’t open it because the program tells me it’s corrupted.
Is there any way to recover or fix it?
Hi @alessandrolonoce22
Which specific file did you delete? Send us a screenshot. Also, please check your recycle bin.
Hi, Thank you for your answer
I have eliminate the whole folder, that appear usually when you save for the first time a file, except the .drs, file, and in fact, I don’t know which screenshots make.
I have checked also my recycle bin, but it is empty.
I don’t think we can recover it, given that the only thing that remains now is your .drs file, sorry. :sweat:
You need to be careful when deleting D5 project files. They have a unique multi-folder format where different folders hold essential information for the project to function. We’re planning to optimize this soon, but for now, I recommend zipping these files for archiving to prevent any accidental modifications.
Did you find solution ?
Hi @connect2
What’s your full situation? We can’t recover files that only have the DRS file remaining.
my file has bak. and i had crash in drs file so i rename the bak. file to drs. and it opened but i cant save it
Hi @connect2
We highly don’t suggest that method, please revert to its original format (names). If you wish to access your backup files, you can access it via “Recent Tabs” > Right Click on your project > Open File Version History
version history
