Hi D5 team!
I am having a issue in my render. There is a light appearing on the ceiling, just like it has not been closed. I checked the model and even created another ceiling on the top of this one, but this light still comes through it.
How is it possible to fix It? I need to do larger scenes and I am worried about it. Can I really trust the render for greater jobs?
Thank you!
Hi,could you please send your project folder and with some screenshot to my email:2353817277@qq.com, we must do some test. thanks a lot!
Hi John
I have the same problem like Atherra and i dont know what to do .
Do you have the solutions ?
Hi, @joseph.bou-chacra if you made sure the model is double-sided and there were no overlapping, please try lowering the specualr parameter for the material in this area
Hi, press shortcut L to show all light sources, please check which light casts shadows on the ceiling.
Also, with regard to the light leak issue, please follow the advice of Vicki, making sure the model is not single-sided.
Hello.
Thanks for you both the quick answer .
I tried the solution of the Specular parameter and i think it works
Best regards .
joe
