Hi, image/decal graphic with transparency from sketchup is not showing up in 1.6 and doing just fine in 1.5.1
I use rtx 2060 and have updated graphic driver to 442.92, anyone can help? many thanks.
Hey there you need to change the image type for the material there is now one especially for images with alpha. Can’t recall the exact name as I am away from my machine but if you click on material types it should be easy to spot
I had the same issue
I hope that helps.
edit: just checked and the material template type is ‘custom alpha’
