D5 Render is a GPU-based renderer that uses DXR and ray-tracing technology. Choosing a higher GPU specification will result in faster rendering and better handling of large projects. A higher GPU capability allows for easier management of larger files, improving overall statistics.
Regardless of your GPU specs, D5 Render provides default rendering quality, with differences only in rendering time rather than quality.
Thank you. I hope I was able to provide good input regarding your inquiry.
As maslu said, BUS of Gpu is important for handeling the work and making the work fluide.
I closly look at the difference between 4060 ti 16 Go and my old 3070 8 Go.
Nothing realy change in thermes of Gpu bus except the volume of memory.
But when you compare 4060 ti 16 Go ad 4070 Ti Super 16 Go, the amount of capacity of treatment of the bus is much more important.
