TITAN RTX 24 GB not support?
HOW CAN I FIX THıS PROBLEM.
resim_2022-09-04_161918486
Hi @academymasterclass ! Please check this post: [Hot issue] Cannot pass the hardware test due to GPU not detected correctly, which will help you solve this issue.
Hello, it seems it cannot pass the benchmark test, but it can run D5 with no problem. Try this way to bypass the benchmark test, then run D5 again.
D5 RENDER - GPU TRICK - ERROR- LOADING OPEN - FIX NVIDIA - WORKING WITHOUT GTX 1060 6 GB - YouTube
