D5 Render Version: 2.6.1.0401
Graphics Card: RTX 4070
Driver Version: Studio 551.23
Issue Description: After upgrading to the latest version of D5 render I have noticed that the real time sharpness of the project has directly disappeared and it becomes very difficult to work with the textures as it was before. I would like you to give me a solution: uninstall and install a previous version, some new parameters … (I have dlss3 activated and it doesn’t improve).
The curious thing is that when I make the window small it seems that the resolution is correct to appreciate the details so I think the problem is that the resolution of the real time viewer is very low and in big monitors like mine (34 ‘’ 3440 x 1440 pix.) when used in full screen makes it impossible to work.
I hope for an improvement or solution as soon as possible, thank you.
Hello, many thanks for your support, the problem has been solved.
There is actually a big improvement in quality. Thank you.
Unfortunately this caused my FPS to drop from 30 to 17 (on RTX A4000)
The fps could indeed be related to the screen resolution. Higher resolution screens can cause a drop in fps, so the “adaptive system scaling” option can be turned on or off. Whether you turn on “adaptive system scaling” or not, it will not affect your final rendering quality.
