I have a problem because after adding the grass material, the sides of the element do not cover the texture. Maybe some of you know how to fix it
Hi, we have discovered a grass material template issue and we are optimizing it. If you prefer to use the grass material template, you can fill the gap by using the same grass model from the D5 asset library. Here’s a link to a related article: Grass Material Template using tips & edge issue - Get Help - D5 RENDER FORUM
