**D5 Render Version:**2.8
Graphics Card: RTX 4080
Issue Description:
I can not rotate the texture
Anyone know what could be wrong?
Issue Description:
What software are you using? Did you UV-unwrap before importing?
Hi there; sorry for the inconvenience this issue has caused. Can you check if you have enabled the feature “Individual UV” in this material? Usually, when this is enabled, the texture will have a separate UV wherein you can adjust it in the slider that appears when it is turned on. Hope this helps, thank you~
Thank you both!
I deleted all and created a new material and now it works.
I must have messed some settings up, but am not sure which ones.
