Merhabalar, d5 renderı bilgisayar kurduğumda system ınfo yazısı çıkıyor ve kapattığımda d5 renderdan tamamen atıyor.
HI.
When you install D5 and check whether your system is suitable or not you don’t have to turn it off you have to go through its installation course, the program sees if you have the ability to run the software having many gigabytes and the suitable graphics card such as the GTX 1060 or RTX onwards with Ram above 6G
Is there any error message? If possible, please show us a screenshot of the problem.
Merhabalar,
Bu uyarı kapatmadan programa devam edemiyorum, amd 5600xt ekran kartı ve 32 gb ram bulunmaktadır bilgisayarımda.
Güncel hali böyledir. Bu uyarıyı kapattığım zaman programdan atıyor.
hi mate, unfortunately, AMD 5600xt is not supported by D5 Render.
You can try this way to bypass the hardware test then run D5, though i am not sure whether it can work well on your device.
Bypass D5 Benchmark test | Use D5 Render with Titan X - Get Help / How to - D5 RENDER FORUM
