How is possible to sync object movement in the path (path tool) with camera movement (in video render)?
In “edit mode” of version 2.6, the object was moving in the loop and then I was possible to switch to “video render mode” and right at this moment object was fixed on the position. So it was possible to sync object and camera movement.
Now, in 2.7, the objects in the path tool do not move in “edit mode”, so I can’t sync object and camera movement.
How can I change the object’s position on the “path” and determine his position in the video render? I need to determine and sync the object position with the rendered sequence.
Hi
Do you have a recording to clarify? When I tested it with 2.6, the characters in the path would remain still as long as I went into Image mode and Video mode.
