Super Resolution cause screen flickering when Camera resolution is different than viewport resolution - especially when it is set to 2K and more.
Hi @Smolak
Apologies for the inconvenience caused. Could you please help clarify a few details:
- Does the flickering happen every time Super Resolution is enabled when the camera resolution differs from the viewport resolution, or only in certain cases?
- What viewport resolution are you using when this occurs, and does the flickering stop if the camera and viewport resolutions are set to the same value?
- Does this happen in all scenes, or only in specific or heavier scenes?
If possible, could you provide a short screen recording showing the flickering and your resolution settings? Thanks in advance, and I look forward to your update.
