Strange colours
**D5 Render Version: 2.6.1.0401
**Graphics Card: RTX 3060
Driver Version:
Issue Description:
recently i got strange colours on some plants and a pink glow around it in preview and final render). i did a graphics driver update and the problem was solved. but today i opened the file and the problem is here again.
So, what may cause this problem?
Hi, you have to update the driver again, the one you show is old, the new version is 552.22
colour4_nv
driver is studio 551.86
two weeks ago it worked with this driver. nothing in the file was changed since then
but i will try newest driver
You have a good, very powerful graphics card compared to mine, with a lot of GB, but you have to connect to the NVIDIA GEFORCE EXPERIENCE app with an account. So it is much simpler because it connects with the D5 program
you were right. with the new driver it works (for now :wink: )
but it’s still strange to me, that a configuration works one day but won’t, without any change, the next one.
THX for your help!
Thanks so much for your help.
Glad that you have solved your issue. If this happens again or some other issue occurs, feel free to contact us.
today i opened the file again and it looked fine. but after importing a skp-model it changed to this
once more.
i closed D5, opened the file i again and all was ok.
imported the same model again, all ok. at least for now
looks like a bug to me because it’s always the same plants that turn to this bright pink colour.
Hello, I noticed that the software you are currently using seems to be version 2.6. You can try opening your file with our latest version 2.7.1 and check if the issue still exists.
i can’t because of some older projects.
but i can try on other computer. there it is version 2.7.0.0443 but it doesn’t say there is an update available. do i have to reinstall to get 2.7.1?
