Strange behaviour of texture with Archicad plugin
V 2.0.1.0313
NVIDA RTX 3060 TI
496.49
Issue Description:
There seems to be an error exporting from Archicad using direct plugin. There is this area over the door which behaves quite odd. On the other side, I tried exporting the same model as an sketchup model and import it in D5 and the problem is gone.
Archicad plugin
Skp model
Thanks for submitting, could you help to send this Archicad file to my mailbox (jingming.liu@d5techs.com) so that we can check that?
I have also encountered a similar problem in a project in archicad. The problem was two walls overlapping by about 8 inches. Solved by arranging the two walls.
L
I’ll send you the project. But @paperless is right. I had a front face of a slab overlapping the wall
Moving back the face of the wall solves the problem. But the question is that a Sketchup model exported as it is works fine. Maybe the plugin needs to find out what geometry is duplicated and remove it from the export.
Thanks
You were right. I had a front face of a slab overlapping with the wall (which is a pretty common working process in Archicad). Moved back the edge of the slab and the issue is resolved.
Thanks for the tip
