Hello there. Congratulations for the software that really look promising.
I noticed some bugs:
When I export a image using the preset sizes (2k, 4k), D5 doesn’t crop the render channels and saves files with bands of black pixels (see images attached).
The fbx import doesn’t preserve texture. Why can’t we import assets .skp format ?
Questions:
- How is possible simulate translucent material, like a curtain in front of a window ? With cloth preset and opacity options ?
Thanks and good job.
prova_04|690x363
prova_04_channel_AmbientOcclusion|690x396
Hey Evilseraph,
Thank you for your feedback.
- We’re checking the export bug, will get back to you if we get result
- Fbx import doesnt preserve now. We recommend D5 convertor if you use 3dsmax and Vray.
- Please check out the last material in “D5 material library - cloth category” and the opacity can be customized on right side panel.
Enjoy.
Hi there,
As for the first bug, may I have your scene file to help us reproduce the problem?(the zip file including drs, asset, material)
my email is - minjia.huang@d5techs.com
Thank you very much
Same first bug with me, also with custom size. First is screenshot, second is 16:9 export (default res), 2nd is custom size export (2560x1440px). Both images are with 115° FOV. Also setting custom size don’t show clipping areas.
Hi there,
Thank you for feedback.
It’s a known issue and already been fixed. Will be released in version 1.6
